Maybe we should wait until he runs out of pills ;-)
Jan
I'll wait until you run out of insults. Just ignore this thread and go do whatever you were previously doing. Don't you have an magazine to write? That's cool you know, working at a magazine.
Jan
Maybe you should wait for the design in this thread to stop working
I'm inclined to agree. The current "stream of consciousness" in this thread does not really convey useful or helpful information. 808eengr, you might consider drafting your posts in a more coherent fashion 🙂
Duly (Differentially) noted
then the frequency transform of the correponsive LPF (a box) varies accordingly
What exactly are you trying to convey in all these posts. Are we looking at op-amp theory?
it's a thread
v.047
HTML:
<a rel="license" href="http://creativecommons.org/licenses/by-nc-sa/4.0/"> <img alt="Creative Commons License" style="border-width:0" src="https://i.creativecommons.org/l/by-nc-sa/4.0/88x31.png" /></a> <br /> This work is licensed under a <a rel="license" href="http://creativecommons.org/licenses/by-nc-sa/4.0/">Creative Commons Attribution-NonCommercial-ShareAlike 4.0 International License</a>
thd+n @4kHz 2VRMs differential 125R 32mw 3.2uV DC offset
v.047 with OPA1656 quad buffer
thd (thd+n) @4kHz 2VRMs differential 125R 32mw 3.14uV DC offset
New layout allows multiple feedback filter for OPA1642 composite amplifier configurations
....and v.074 is a low power version and ready for sim
Jan
Who lets you say whatever you want?
I think your words are just that... words
Results Didder. Results
v.074
v.074 with dual AD8597 and OPA1642 quad buffer
thd @4kHz 2VRMs differential 125R 32mw 3.14uV DC offset
Total Harmonic Distortion: 0.000073%
thd @64kHz 2VRMs differential 125R 32mw 3.14uV DC offset
Total Harmonic Distortion: 0.000161%
the system couldn't resolve at 1k
run at 4k and 64k
anyone is square law up for a diff eq to approximate 1k thd
(f^n)*(n^n)
[(f^2)*(2^2)=f1, f=1k, n=2;] //(2VRMS 😕)
[(f^2)*(2^2)=f4, f=4k, n=2;]
[(f^2)*(2^2)=f64, f=64k, n=2;]
my coding is in need of a c++ update for sure
run at 4k and 64k
(f^n)*(n^n)
Vuelo Fully Differential Hybrid Amplifier
(transresistance amplifier)
v.074 low voltage with AD8597 voltage gain stage and quad || OPA1656 current gain stage
using:
AD8597ARZ-REEL7DKR-ND
296-OPA1656ID-ND
thd @1kHz 1VRMs differential 125R 32mw 3.14uV DC offset
Total Harmonic Distortion: 0.000036%
thd @1kHz 2VRMs differential 125R 32mw 3.14uV DC offset
thd @1kHz 4VRMs differential 125R 32mw 10.34uV DC offset
Total Harmonic Distortion: 0.001675%
square wave response 100kHz 100mV Single Ended (Vin- to GND)
using:
296-OPA1656ID-ND
VUELO_4_LAYER_v_074_AD8597_OPA1656_2VRMS_1k_freq_dist.pdf342 KB · Views: 71
VUELO_4_LAYER_v_074_AD8597_OPA1656_1VRMS_1k_freq_dist.pdf582.1 KB · Views: 77
Vuelo Fully Differential Hybrid Amplifier v.0741
(transresistance amplifier current gain stage complete)
v.0741 low voltage with AD8597 voltage gain stage and quad || OPA1656 current gain stage
changed AD824 to AD823 over V/us error correcting integrator, adjusted component values
added 47 milliohm R's
2nd Harmonic is now ~ 90deg neg phase
DC offset now .7uV
thd @1kHz 2VRMs differential 125R 32mw .7uV DC offset
using:
296-OPA1656ID-ND
LLC450HB-0R047-ND
over 3 million frequency series points 🙄
Date: Mon Jul 13 08:27:26 2020
Total elapsed time: 1232.752 seconds.
tnom = 27
temp = 27
method = modified trap
totiter = 7349283
traniter = 7343403
tranpoints = 3671543
accept = 3671139
rejected = 404
matrix size = 689
fillins = 2711
solver = Normal
Matrix Compiler1: 350.52 KB object code size 748.1/42.0/[18.4]
Matrix Compiler2: 104.40 KB object code size 22.0/29.9/[12.1]
DC offset now .7uV
using:
296-OPA1656ID-ND
LLC450HB-0R047-ND
tnom = 27
temp = 27
totiter = 7349283
traniter = 7343403
accept = 3671139
rejected = 404
matrix size = 689
fillins = 2711
solver = Normal
- Headphone Systems
- Fully Differential Headphone Amplifier
