Group Buys Members group buys
Ideal bridge rectifier GB
Old 12th February 2019, 07:44 AM   #11
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
There was a very positive buzz on this forum about the combination of LT4320 and the GS61008T.
The idea of sync rectification for audio sounds great in theory but i have no idea what is sounds like in an actual amp. Sometimes great ideas translate into great sound, but sadly not often.
Old 12th February 2019, 07:44 AM   #12
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Maybe you should explain a bit about synchronous rectifiers, not everyone will be up to speed, and realize the benefits of rectifier diodes with zero threshold.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 12th February 2019, 07:51 AM   #13
vega65 is offline vega65  Norway
I would like to sign up for 6 pairs . Will use them in front of Rod Colemans filament regulators. Well done Tibi!
Old 12th February 2019, 07:55 AM   #14
jan.didden's Avatar
Ohh yes, they would be ideal for filament regulators, you're always fighting for the last volt there from a 6.3V AC winding! Good idea.
Jan
Old 12th February 2019, 08:04 AM   #15
tvicol is offline tvicol  Europe
tvicol's Avatar
Ideal bridge rectifier GB Ideal bridge rectifier GB
Thank you, analog_sa ! GS61008T is an impressive device.
Tibi
https://evotronix.eu
Old 12th February 2019, 08:09 AM   #16
secanbj is offline secanbj  Sweden
very interested
Old 12th February 2019, 08:21 AM   #17
Art M is offline Art M  United States
Jan
I am a Bit confused here as: - AC operating voltage 6,5Vac to 51Vac
- DC operating voltage 9Vdc to 72Vdc
In any case, how can these be " zero threshold " as FET drive required.
Old 12th February 2019, 08:43 AM   #18
jan.didden's Avatar
You can always feed a bridge with DC. Normally it doesn't make much sense but is does work fine.
Edit: 51VAC is RMS which is 1.4 X DC, ~ 72V...
The synchronous rectifier generates an internal source that is used to switch on the MOSFET as soon as the Vds starts to go up after zero crossing of the input voltage.
You could also click the link the OP has given ;-)
Jan
Old 12th February 2019, 09:14 AM   #19
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Interesting timing as Janhofland, myself and AKSA have just designed an active bridge using this chip for making 5A continuous load ideal bridge rectifier for a large Class A amp in order to reduce the huge thermal losses from a traditional diode bridge at these kinds of current. I ran across the LT4320 chip about 3 weeks ago. Board still needs to be ordered and will test soon.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th February 2019, 09:20 AM   #20
Got Foam?
xrk971's Avatar
Jan
A good explanation is here:
LT4320 Ideal Diode Bridge Controller Cuts Power Dissipation, Improves Efficiency | Power Electronics
One thing I am unsure of, is how the transients of the resulting sawtooth wave looks after the bulk cap? Does it even look like a diode sawtooth? Or will it be a total mess? Although, it can't get much worse than a sharp sawtooth in terms of audio harmonic generation.
Ideal bridge rectifier GBHide this!Advertise here!
bridge rectifier rock12 Power Supplies 4 15th January 2017 09:06 PM
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Copyright ©1999-2019 diyAudio
