Group Buys Members group buys
Simple High Performance DC Coupled Class A HPA with sub PPM THD
Old 18th October 2018, 02:10 PM   #291
avtech23 is offline avtech23  Australia
Certifiably addicted to DIY.
avtech23's Avatar
Originally Posted by xrk971 View Post
Hi Avtech,
Your board will go out tomorrow to Oz.
Thanks,
X
Boards received, thanks!
The ever growing project list.. :NAP140 Clone, NAD 3020i & 3225PE, JLH1969, TDA2050, Fender 5F2A Princeton, NE5532 Preamp | : VSQC Phunk Style, Retro 50W | Filmosound 601 | SHPA | : Apex AX-14 | TGM-10 | TDA7265 | LM4780 (Last in line)...maybe
Old 18th October 2018, 03:25 PM   #292
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Thanks for letting me know - did that really take a month to get to OZ?
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th October 2018, 10:33 PM   #293
avtech23's Avatar
I was interstate for a couple of weeks, so I think it only took about a fortnight in the end.
Old 20th October 2018, 02:10 AM   #294
Got Foam?
xrk971's Avatar
Another option for a power supply for this amp if one wanted to use a linear supply would be the new Mark Johnson/Gtose cap multiplier. Beautiful layout by Prasi. This cap mx board has advantage that there is a pot to adjust dropout voltage from 1.3v and up to about 2-3v. So one could set perfectly balanced upper and lower rails at +/-18v.
Juma's Easy-Peasy Capacitance Multiplier
Old 24th October 2018, 02:59 AM   #295
yourownbuzz is offline yourownbuzz  Australia
from a quick look at the thread it looks like it needs both + & - inputs....or does this board also split single rail to dual rail?
it does look pretty impressive and imposing though
Old 24th October 2018, 07:09 AM   #296
Got Foam?
xrk971's Avatar
Thatís a dual rail cap Mx board. Prasi just made me a smaller layout of a version of this board using SMT components and TO220 BJTs and an on board rectifier bridge to make lower current (1A and under) dual rail output.
File Type: png 1AD60326-D212-437A-B947-EF423AECDE6B.png (52.0 KB, 662 views)
Old 24th October 2018, 07:17 AM   #297
ernesternest is offline ernesternest  Europe
ernesternest's Avatar
Nice and small, yet great ;-)
Old 5th November 2018, 09:09 AM   #298
finally ordered the parts for the amp ! got the meanwell power converter instead, for anyone thinking about getting it - its much larger and no way of fitting on the pcb
X:
with heatsinking of the mosfets, would the same ones you used for the power regs be fine? or does it need something beefier ? (I seem to remember you hooking it up to a pretty big heatsink with CPU fans...or was that another thread?)
heatsink on power regs as in this post - Simple High Performance DC Coupled Class A HPA with sub PPM THD
Old 5th November 2018, 04:02 PM   #299
Got Foam?
xrk971's Avatar
That was another thread. This amp works fine if you simply use the baseplate of the amp as a heatsink. 18v x 125mA is about 2w per MOSFET so 8w total.
Old 18th November 2018, 01:01 AM   #300
Harry3 is offline Harry3  Australia
Default Input resistors
Hi
What is the purpose of having a 2K2 resistor and a 100R resistor at the input?
Can I short one out eg the 100 R or am I missing something?
I’m asking because I’m trying to cut down the number of components on the input side.
PS do you need a regulator with the cap multiplier above?
Simple High Performance DC Coupled Class A HPA with sub PPM THDHide this!Advertise here!
Ultra-high performance, yet rather simple - hybrid and more! vzaichenko Solid State 998 13th June 2018 12:12 PM
High Performance Class A Current Feeback Headphone Amplifier monty78pig Headphone Systems 14 12th November 2015 02:01 PM
Simple High-Performance DAC psk Digital Line Level 17 8th September 2014 05:41 AM
simple, high performance amp using DRV134? Fast Eddie D Headphone Systems 6 6th May 2014 06:17 AM
Huginn, High performance, Class A, Lateral FET headphone amplifier Neutrality Headphone Systems 11 7th November 2013 08:29 PM
Copyright ©1999-2019 diyAudio
