Vunce,
I was also wondering about how the caps were handled by hot air. Thanks for the tip. Hopefully that tiny diode will be nice to me. I bit the bullet and ordered up some 10K ohm 0805 size for R2, rather than trying to fit a 0603 across the pads (see post 617).
Thanks all for the help.
This is fine. That 10k doesn’t dissipate any heat. The 0805 size was more for ease of installation.Hi X,
I made a mistake on my BOM for the 0805/1206 DB's. I only ordered the 10K ohm 1206 size for R10, and forgot about R2.
R2 needs to be 10K ohm 0805 size and 1/8W. I have some 10K ohm 0603 size and 1/10W that I ordered for the PDM board. I think I can make it just fit on the DB pads. Is it OK to use it, as it is a little less wattage?
Thanks,
MM
