Tapered Wave Tube with Damp-Duct (TWTD) + Pluvia7HD
Driver is mounted 1:1 and damp-duct 1:5.
Sound absorbing material is minimal.
Reactions: Michael Marmaras
Dear,cogitech
Part7 & 8 =60mm
---- Pluvia7HD + TWTD at YouTube ----
Tapered Wave Tube with Damp-Duct (TWTD) [or ML-Voigt] [or "Sifted Mouth-TQWT"] + MarkAudio Pluvia7HD - YouTube
0:00 Orinoco Flow - Enya
4:26 Estrellita - Yuko Oohashi
9:00 Softly As In a mornbing Sunrise - MJQ
15:21 Suliko
17:36 Temptation - Diana Krall
[Playback System]
PC(Win10)
TOPPING E30(DAC)
Softone Model8-300B(Tube Amp)
MarkAudio Pluvia7HD(TWTD-10T)
[Recording System]
PC(Win10)
TASCAM 102i(audio interface)
AKG P220(at 2.5 meter)
Dear, azubinski
It's also a good match for Alpair7MS.
7MS has gentle treble and muscular bass.
---- Alpair7MS + TWTD at YouTube ----
Tapered Wave Tube with Damp Duct(TWTD) + Alpair7MS - YouTube
15:21 Suliko
[Playback System]
PC(Win10)
TOPPING E30(DAC)
MarkAudio Alpair7MS + Tapered Wave Tube with Damp-Duct (TWTD-10T)
[Recording System]
PC(Win10)
A good horn/TL modeler required. One could easily start with a Pensil, transform it into a Voigt, then fold it. I think i have an unfolded one in my CAD (A10, A10.3, A10p, A10.2 likely not much different), and we have folded versions for FE108e∑ & FF165wk that look like the visualization i posted.
dave
I obviously am not nandappe, but.
There is a well-known web address at his drawings, which explains a lot.
It's a very interesting source of information and designs, with the own practice based "rules of thumb" methodology (google translate will help).
Dear, jjasniew
I'm recording 2.5 meters away. (96kHz, 24bit recording)
After recording, fade-in, fade-out, and normalize (up to MAX 0dB) are processed.
After that, use the Windows video editor to match the image and sound, and then upload it to YouTube.
I think you can play back with headphones or speakers, but you can feel the atmosphere by listening with headphones.
However, you cannot hear the bass that shakes your skin with headphones.
[Recording system]
PC (Win10Pro, 64-bit)
TASCAM 102i (audio interface)
AKG P220 x2 (microphone)
WaveLab LE 10.0 (recording soft)
Reactions: deanznz
Hi Nandappe,
Congratulations on your wonderful mass-loaded tapered TL design! I finally got a chance to connect a headphone amp and some good headphones to listen to your YouTube recordings. Very nice natural sounding and well balanced. Your recording setup is very impressive with two AKG diaphragm shock mounted mics. They sound better than a Zoom recorder with electret mics that is for sure!
Your room is actually quite good - I do not hear a lot of room reverberations, and yet it is not too "cold".
One of the best ML TL Voigt implementations I have seen or heard in a long time - bravo!
:cheers:
If you want to try some easy (reversible) experimental mods, try these:
1. glue some melamine foam sponge pads (BASF Basotect - patent expired) to inside where directly in line-of-sight with driver rear membrane. This will clean up the sound intelligibility by preventing back reflections from interfering with front wave. Will sound closer to an open baffle.
2. Add small amounts of very loose polyfill stuffing in the top 180 deg turn and monitor with impedance sweep to get the two peaks closer in amplitude. Also listen and make sure the bass is not killed off. This will improve the timing of the bass and reduce group delay. Transients from kick drum will be sharper.
3. Similarly, a very thin amount of open cell reticulated fish aquarium filter foam (10mm to 20mm thick) used at the terminus vent can also reduce group delay and flatten the impedance peaks. Use very sparingly as it can kill the bass amplitude. It is a tradeoff.
4. Add a puff of loose polyfill stuffing into the large chamber at the bottom and this will reduce any echo resonances and not affect the bass at all.
Please see attached marked up sketch. These are all doable after the fact and reversible. You can put the puff of stuffing at the bottom in a mesh bag with a string and pull it out the top through the driver cutout if you don't like it. These are all possible tweaks to further refine the sound. As you can see from the measurements, there are small dips and peaks, and these steps may help to smooth all of that out even more.
5. Final mod would be to use a BSC - perhaps 1.0mH air core (18ga) inductor in parallel with circa 3.3ohm (adjust to taste and measurement from 2.2ohm to 6.8ohm) 10W resistor and 0.47uF to 2.2uF MKP film cap (adjust to taste), all in parallel. This will give the speaker the "Harman Room sound" right downwards tilt in the response for a more pleasing balanced sound with highs at 12kHz about -3dB to -5dB less than bass at 50Hz.
attachment.php
