Some questions about the Lii Audio F15 please ...
Thread Tools
Old 16th August 2020, 05:20 AM   #11
GM is offline GM  United States
GM's Avatar
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 16th August 2020, 06:40 PM   #12
jjasniew is offline jjasniew  United States
jjasniew's Avatar
Originally Posted by ernie000 View Post
Hi Joe
Could you tell me please , how far from the wall do your OB have to be ?
This is the main reason why i don`t think I can go OB.
I just can`t get back far enough .
They're 4' from the back wall, 8' more (for a total of 12" from the back wall) to the seating plane of the sofa. As long as I have the tape measure out, about 8' apart, phase-plug to phase-plug on the F15's. There's probably 10' of open space behind the sofa also...
Too bad they're not easily auditioned. I'd think you'd jump on 'em if you heard 'em. However, it's one of those goldielocks things; too hard, too soft, just right - that you'd have to experience yourself, so that said with some caveats;
It's a big FR speaker, so it's going to "beam" or whatever, so that would put some people off regardless of how much of a joy it is to listen to -
It's a FR speaker, so its frequency response isnt going to be nearly as flat as can be natively achieved using other designs, so that would put some people off regardless...
It has some measured parameters that seem to be in an off-place, relative to more common values of such, so that would put some people off regardless...
It's a FR speaker, so its going to IM distort the sound eventually at some sound pressure level, moreso than what can be natively achieved using other designs, so that would put some people off regardless...
I chose my bed and am sleeping comfortably in it - so far! I'm 63 and cannot hear elements in recording I used to be able to. I can still hear instrument placement, depth and other attributes of phase correlated reproduction within the frequencies I can still hear. Depends so much on the recording; if "there" in the recording, my F15 speakers (with the 18" assists) will cast an acoustic bassist almost as if "there" in the room. Even when streaming audio from the Jazz Groove through an iPhone, BT connection to the amp; with no particular attention paid to the bit-depth or encoding of the stream.
This, I like.
Joe Jasniewski - PC>ZOUDIO AIO4CH> OB Lii Audio F15s w/ 18" assists.
Old 16th August 2020, 11:45 PM   #13
freddi is offline freddi  United States
freddi's Avatar
those published specs gotta be 150% hooey
here's more believable
Old 16th August 2020, 11:54 PM   #14
GM's Avatar
Wouldn't surprise me, but what are you basing it on?
GM
Old 17th August 2020, 01:57 AM   #15
ernie000 is offline ernie000  Australia
Too bad they're not easily auditioned... I'd think you'd jump on 'em if you heard 'em...
Thank you for the detailed reply Joe .
Everything you mention makes sense to me.
You have confirmed that I do not have the space to play these in open baffle configuration.
I bet your system sounds very nice.
Old 17th August 2020, 02:00 AM   #16
Not doubting what you say here , but how did you arrive at that plot freddi ?
Old 17th August 2020, 02:26 AM   #17
hitsware is offline hitsware
hitsware's Avatar
If they weren't so pricey ,
I ' d try one in my light weight
cabinet design : )
http://www.hitswares.com/
Old 17th August 2020, 04:18 PM   #18
jjasniew's Avatar
hitsware; If you look closely at my avatar, you can see I've done that with these F15s...at first.
ernie000; There's discussion elsewhere on smaller (8") FR drivers - retailing for a lot less. Maybe a better fit for your room size?
I'm lucky to have the large room, be "allowed" to have these things; they look like two white elephants in it and dominate that end.
Old 17th August 2020, 05:10 PM   #19
hitsware's Avatar
Joe ...
If you look at my " light weight cabinet design "
you will see it is open air . The smaller the diameter
the driver , the more I must EQ .
That is what drew my attention to this thread .
Even 12 inch is pushing things ..... <|:^)
Old 17th August 2020, 10:32 PM   #20
freddi's Avatar
hey Hits, speaking of parameters, I couldn't get WT3 to calibrate/work correctly with DATS software. Win10 on dual boot Mac. Any ideas on how to get it working? (gotta find the dongle !!)
Some questions about the Lii Audio F15 please ...Hide this!Advertise here!
Thread Tools
Questions on Audio Note Kit One aslee Tubes / Valves 19 23rd February 2019 01:12 AM
New to audio with a few questions Dxznn Parts 1 17th April 2016 09:09 PM
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 27 30th July 2014 12:14 AM
Questions about M-Audio Firewire 410 theAnonymous1 Digital Source 2 2nd September 2007 05:31 PM
a few questions on car audio. please help Dj Dfa Car Audio 3 10th September 2003 03:46 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
