How to calculate speaker box size when there was no speaker in the box
Old 12th September 2019, 04:31 PM   #1
mill23bay is offline mill23bay  Canada
mill23bay's Avatar
Default How to calculate speaker box size when there was no speaker in the box
Hello,
I have a pair of Orion HS10 boxes without the speaker. How would I find the right speaker for the size of box. They are well built and would like to use them.
PeterC
Old 12th September 2019, 06:39 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
You can fil the box with water and then measure how much for high accuracy, but you can get close enuff with a tape measure on the inside.
Once you know the box volume, you can take a speaker modeler and plug in potential candidates and see how they do in that volume (or less volume, it is easy to fill up extra space.
Pictures?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th September 2019, 07:53 PM   #3
Galu is offline Galu  Scotland
Here's a picture Dave.
As Dave says, simply measure the internal dimensions with a tape measure and calculate the volume. In my diy world, plus or minus 5% in volume is close enough, but don't tell the purists!
I think Dave was joking re the water. It would run out the driver apertures and saturate the woodwork (and the floor)!
Old 12th September 2019, 08:53 PM   #4
GM is offline GM  United States
GM's Avatar
Basic tutorial: Reverse engineer an existing enclosure.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd September 2019, 06:49 PM   #5
mill23bay's Avatar
Thank you very much!
Old 22nd September 2019, 06:56 PM   #6
mill23bay's Avatar
These are the ones I have.
Old 22nd September 2019, 06:57 PM   #7
mill23bay's Avatar
Sorry, the speakers are not there.
Old 22nd September 2019, 07:08 PM   #8
Ah! Twin cone drivers!
Shouldn't be too hard to shoe in a reasonable substitute.
If you need more help, then tell us the internal volume of the box, whether it is a sealed box (no reflex port) and the diameter of the speaker aperture in the box.
I'm sure someone will be able to suggest a suitable candidate.
Oh! And the maximum that you wish to spend would be very helpful.
Old 22nd September 2019, 07:10 PM   #9
mill23bay's Avatar
Thank you Galu, it may be some time before I get around to, thanks again!
Old 22nd September 2019, 07:12 PM   #10
OK Peter! Return when you're ready.
How to calculate speaker box size when there was no speaker in the boxHide this!Advertise here!
Kerfing MDF - How I calculate | Speaker Build HatlessChimp Construction Tips 0 5th November 2018 06:40 PM
PORT size vs SPEAKER size Tomom Multi-Way 14 27th October 2012 01:09 AM
Calculate Acoustic Speaker Models Knorfski Multi-Way 2 16th February 2008 05:47 AM
Speaker size v Room size cliffy Room Acoustics & Mods 6 19th February 2005 09:34 AM
Formula to calculate speaker impedance Perry Babin Multi-Way 5 21st November 2003 07:19 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
