Even BIGGER than Bigger, Badder BIB...
Old 15th September 2019, 03:13 AM   #91
CraigSu is offline CraigSu  United States
CraigSu's Avatar
Originally Posted by GM View Post
Actually, it needs to be seriously mass loaded, not as much as this alum. horn, but as a general rule make it at least twice as heavy
Would applying a heavy layer of Mortite to the back of the waveguide be sufficient?
Avoid the paralysis of over-analysis: less Think, more Do!
Old 15th September 2019, 05:10 AM   #92
GM is offline GM  United States
GM's Avatar
You would want to cover it all plus ideally lock it in a damped brace back at the motor, though most folks do it at the throat. FWIW, constrained layer damping is my preference and easily done by applying a foil backed rubberized tape for weatherproof flashing [may take two layers]: https://www.homedepot.com/p/Nashua-T...B&gclsrc=aw.ds
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 15th September 2019, 09:09 PM   #93
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
Default Stuffed And Braced
Moar progress!
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
Old 15th September 2019, 10:58 PM   #94
GM's Avatar
Hmm, not sure that's sufficient for a prosound 15"; at the very least I'd 'X' brace the mouth, i.e. notch what you have and notch another cross brace to interlock them, tie all four sides together. Also, run a full panel vertically down the initial expansion or at least a bunch of scrap tied together to create a rigid framework.
GM
Old 21st September 2019, 10:40 PM   #95
BHD's Avatar
Default DONE!
Letting the glue dry a bit before trying them with a boombox.
Old 21st September 2019, 11:35 PM   #96
GM's Avatar
Did you have to put a 'bump' in the divider panel for the horn?
GM
Old 22nd September 2019, 12:12 AM   #97
BHD's Avatar
GM
Sorry, I'm not sure what you mean. I've currently got them running with a cheap chi-fi amp in the garage, they are deceptively loud. They don't sound loud until you try to talk and you find yourself yelling.
Old 22nd September 2019, 12:21 AM   #98
BHD's Avatar
Oh, now I think I get it. No, the horn and the woofer both fit in perfectly with no modifications.
Old 22nd September 2019, 01:29 AM   #99
GM's Avatar
Cool! This the horn? QSC PL-000446GP Replacement Waveguide Horn for HPR152i 2-Bolt
GM
Old 22nd September 2019, 01:32 AM   #100
GM's Avatar
Yup! Loud is Beautiful if it's Clean!
GM
Even BIGGER than Bigger, Badder BIB...Hide this!Advertise here!
BBBIB Bigger Badder BIB Speaker Variac Multi-Way 285 16th September 2012 07:34 PM
Copyright ©1999-2019 diyAudio
