Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#2771 |
Thanks, guys.
The driver is an Aurasound Whisper. They were $12.50 on sale. Aurasound NSW2-326-8AT Whisper 2" Extended Range Speaker Driver 8 Ohm |
#2772 |
frugal-phile(tm)
Thanx, similar construction and size to the ne si mentioned.
dave
Stay safe. Stay home. Respect the 2m bubble. |
#2773 |
I started laying out the 20" plans on the bottom plates and didn't feel like poking all those holes.
So I came up with another approach. I laid my plan on the bottom plate and pushed three pins in for alignment. Then I put the pattern on the second bottom plate and pushed those pins in again. Now I can remove and replace my pattern on both plates and keep the pattern aligned. Then I cut the pattern on the outside line in 90 degree segments. I traced the pattern outline, put it on the second plate, and repeated. Cut on the outside again in 90 degree segments. Trace again. Repeat. Once you get past the second set of vanes you can cut in 180 degree segments. It turned out pretty good. It's more accurate than the hole poking method I used on my first set. It may not make any practical difference, but satisifies my OCD. ![]() |
#2775 |
Beauty
#2776 | |
Speakerholic
Damn the torpedoes, full speed ahead! ![]()
http://www.calweldonconsulting.ca/ |
#2777 |
frugal-phile(tm)
Harald,
I have some tricks that help tame the FF125wk. dave
#2778 |
Speakerholic
What are you taming Dave? I found that driver rather subdued in it's delivery.
#2779 |
frugal-phile(tm)
Wasn’t yours already worked over?
Stock they have some ringing that takes some tweaks and long brealin to minimize. dave
#2780 | |
Got Foam?
XRKaudio https://www.etsy.com/shop/XRKAudio |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Cornu Spiral Copy Horn | hersh | Full Range | 25 | 30th January 2018 02:32 AM |
Line array cornu spiral? | jaylgordon | Full Range | 7 | 15th December 2013 08:43 PM |
Cornu spiral horns | Cal Weldon | Multi-Way | 3 | 14th July 2004 03:51 PM |
New To Site? | Need Help? |
