Foam Core Board Speaker Enclosures?
Old 23rd May 2020, 05:55 PM   #3151
georgemarousek is offline georgemarousek  United States
georgemarousek's Avatar
Thanks for the comment, now on to get some foam board.
Question on the construction of the foam cabinet. I get using a hot glue gun to assemble the horn, back, front, top and bottom to one side but what do you use to seal on the other side, Liquid Nails?
George
Old 23rd May 2020, 06:11 PM   #3152
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Hot melt glue if you are fast! Or white PVA glue works well too and is clear. Liquid Nails is brown and makes a mess. Only use the non VOC version.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 23rd May 2020, 08:07 PM   #3153
Forgot about PVA, thanks
George
Old 31st May 2020, 05:04 PM   #3154
When use used the Mr Clean magic eraser as a damping material did you use them straight out of the box (with the "soap" still in it) or did you wash and dry them?
Have decided on the 0.40X design for my first build with foam. Have build 17 MDF speakers so this will be a new experience!
George
Old 31st May 2020, 05:46 PM   #3155
Got Foam?
xrk971's Avatar
I don't think they ever have soap in them. They only need water to remove stuff like wet sanding. Get the bags of 100 sponges from China for $10 if you can wait.
Old 2nd June 2020, 06:19 PM   #3156
Sorry for so many questions but I would like the enclosuers look nice and not like a kindergardner glued them.
I get it that the glued edge of the first side is all from the inside so that edge looks nice and clean. But what is recommended to glue the other side on? Do you just run a bead of PVA along the edge of the side and a fine thread of glue on the upright pieces and assume that that is adequate?
George
Old 2nd June 2020, 06:45 PM   #3157
Got Foam?
xrk971's Avatar
Yes, and place lots of books on top to clamp them all down while waiting to dry. White PVA is clear and doesn't leave a visible trace. You can cover the foam with fabric or even wood veneer if you like.
Here is an example of fabric covering:
Old 6th June 2020, 09:13 PM   #3158
In brousing the thread I picked up the information that the Karlsonator is a tapered quarter tube with an acoustic lens. Any information regarding the theory of the acoustic lens and how it behaves and performs the task it does?
George
Old 7th June 2020, 12:55 AM   #3159
Got Foam?
xrk971's Avatar
Much of the theory on TQWT can be found in other websites like Quarter Wavelength Loudspeaker Design
Theory Karlson acoustic lens and model is in this thread:
A Speaker that Kicks Butt in Large Spaces
Karlsonator is close to mild tapped horn in some ways - with a weakly coupled bandpass output coupler with the K aperture.
Old 7th June 2020, 02:59 AM   #3160
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
That enclosure came out nice, X!
Foam Core Board Speaker Enclosures?Hide this!Advertise here!
Replace speaker foam with this odd material? flyingsquirrelman Subwoofers 10 3rd March 2015 07:44 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 4 11th February 2014 01:14 AM
concrete board for enclosures? alandarkdale Multi-Way 6 31st March 2007 08:35 AM
Foam core construction for subwoofers morbo Subwoofers 19 30th August 2005 08:09 PM
speaker foam dave k Multi-Way 2 24th June 2003 05:05 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
