Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Modification of MHZS CD players
Thread Tools
Old 18th September 2021, 07:31 AM   #181
tonimxp is offline tonimxp  Italy
I found wrote ecc88 can work fine with V plate 150v or so.
Can ecc88 to be a alternative tube for solve my problema?
Old 18th September 2021, 09:40 AM   #182
McGyver is offline McGyver  Poland
McGyver's Avatar
ECC88 has different pinout and much more gain than 12AU7.
Old 18th September 2021, 11:52 AM   #183
Originally Posted by McGyver View Post
Second cathode resistor could be 47k/2W also.
The gain will be about 8.
I need gain =1 becouse input tube stage is already 2.2 Vrms and in out i have 2.7 Vrms
instead input opamp is 1 Vrms so opamp gain=2 or so
Old 18th September 2021, 01:03 PM   #184
McGyver's Avatar
You need to omit an opamp and to obtain gain of 2. Wchich is difficult to get with popular small tubes without negative feedback.
You may obtain the gain about 3 with 12B4A tube, but default power supply is insufficient.
Old 18th September 2021, 01:24 PM   #185
This Is what already happens with the configuration of my post 177, so gain Is ok.
I also saw that at your post 18 you used ecc88 with 120V , what Is the gain in ecc88 your solution of post 18?
Old 18th September 2021, 01:57 PM   #186
McGyver's Avatar
It was eleven years ago, I do not remember it clearly enough.
When I look at it after several years, I can see that it could be done much better.
  Reply to this post
Modification of MHZS CD playersHide this!Advertise here!
Thread Tools
List of Mod-able CD Players DreadPirate Digital Source 2 26th February 2012 06:22 PM
Quality of Mp3 Players ! -_nando-_ Everything Else 21 1st May 2006 05:42 PM
CD Players deanbo Digital Source 3 25th July 2005 05:57 AM
CD & DVD players f.s. Cobra2 Swap Meet 6 16th March 2004 07:26 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
