Finally, an affordable CD Transport: the Shigaclone story
Good job with the boards Oleg! Will you be sharing the gerbers or selling the boards? I have several broken Shigas, I might be able to salvage the chips from them or from the EZ31 I just bought if I had a new pcb. I think it would be great for the community if there was a way to build more of them. Do you happen to know a reliable source for the chips? I've bought some from Aliexpress, from vendors who have sold me genuine obsolete transistors in the past. As far as I know there is no easy way to test if they are counterfeits.
Reactions: 1 user
First and second mods on this draw in attachment
On MKII version is little different design by ITiberius
I draw with better place 680pf and transistor near chip for better reading of the CD-R and SACD
I am looking for the exact model naming of the associated SANYO mechanism for pick up (laser) units as follow:
1) SF-P101 (here I have found only various versions from SANYO's DA series e. g. "DA11V" - go to datasheet under
https://www.tradeeasy.com/home/aceltd/425678/DA11VZ.pdf
and DA11T3C - no datasheet to find - only mentioned under
https://www.classic-serviceparts.com/(S(wxshwp32jvcicvermhurtm1x))/Download/20170110_laser.)
2) SF-P1 (no information)
3) SF-90 (no information)
4) SF-91 (no information)
Unfortunately the Vasiltech overview don't mention this - only the types of optical pick up is to find.
Maybe one of the members know this.
On the mechanism, which is to replace there is no sticker for reading the model resp. type No (like to observe on SONY mechanism from KSL/KSM series for KSS laser units).
Thanks for any advice.
Maybe with help of all datasheets one get an answer to the question under
https://www.diyaudio.com/community/...sf90-cross-compatibility.383531/#post-7678301
