Behringer DCX2496 mod - what to do with RS232 port?
Thread Tools
Old 10th February 2021, 03:22 AM   #1
tommus is offline tommus  United States
Default Behringer DCX2496 mod - what to do with RS232 port?
I am working on a mod to the DCX that involves removing the input/output board. I want to keep using the RS232 port. Can I just go from the D-sub pins to the input on the DSP board? Or is there some sort of circuitry on the I/O board that processes the D-sub input? Thanks.
Old 10th February 2021, 04:23 AM   #2
Davey is offline Davey  United States
No, no circuitry, but a few of the handshake lines (1,4,6) on the DB-9 connector are looped. But your connected computer/cable probably won't care if it sees those.
Dave.
Old 10th February 2021, 05:10 AM   #3
BesPav is offline BesPav  Russian Federation
I'll drop rs232 out and provide or I2S input with masterclock out from DCX2496, or I2S output of 3 pairs stereo for external DACs like DBX 4800 do.
Old 12th March 2021, 01:36 PM   #4
tojoko is offline tojoko  Netherlands
Default DCX2496
Dave.
Hi
Does someone have a schematic of the RS-232 connection to the mainboard?
Have replaced the OutputPCB for a passive (diy) board and want to keep RS-232 function,
Cheers, Tom.
Old 12th March 2021, 01:55 PM   #5
You need 3 pins from the small header: #9, 17, 18
These correspond to pins 5, 3 and 2 on the D-sub.
5 is ground, 2 and 3 are Rx and Tx.
(I mixed up Rx and Tx when building and I forget which is which)
I used a D-sub connector with a Phoenix style breakout board and wired the loopbacks onto it.
Jumper pins 1+4+6 together, and also 7+8.
Just make sure the connector you get will fit between the chassis wall and power supply.
Old 15th March 2021, 08:55 AM   #6
Default passive out DCX2496
Hi
Thanks!
Tojoko.
  Reply to this post
Behringer DCX2496 mod - what to do with RS232 port?Hide this!Advertise here!
Thread Tools
FS Behringer DCX2496 Full Selectronic Mod tojoko Swap Meet 0 12th January 2021 02:04 PM
Behringer DCX2496 with Linear Audio mod (6ch vol ctrl) Yo_Azazel Swap Meet 0 21st June 2016 10:52 AM
FS: Behringer B2031A Pair (Some say they beat Orion!) and Behringer DCX2496 bmwparts Swap Meet 10 17th December 2014 01:58 PM
FS: Behringer DCX2496 with digital output mod Spiritzly Swap Meet 1 15th October 2006 02:08 AM
RS232 Relay Control (Logic) Morbid Digital Source 4 21st July 2004 02:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
