Hello All,
I recently bought a fresh new K702 headphone and I was looking forward to buy a Dragonfly black or maybe the red to match my headphones.
and while I was googling for the other USB DACs, I came across this DAC in the Kickstarter page.
Adapt Audio DAC - SOUND UPGRADE for MUSIC LOVERS and GAMER by Dense —Kickstarter
I heard some good and bad things about crowdfunding, but just by the specs at that price point, maybe I could wait just a little bit.
Now I'm trying to decide.
1. Just go with the proven Dragonfly DAC
2. Take a little risk and buy the kickstarter one
Can anyone help me to decide?
How are they going to generate sales? There's nothing in the funds allocation for marketing and without this, its a lame duck, no matter how good it is.
I've seen great products flop before because the designers fail to consider how they will actually market the item. (what is the selling price?) They seem to believe that their products will sell themselves.
If you aren't in a hurry then you might possibly see it reach production, but they are a long way off their target and only have 26days left.
Probably about the same as this;
USB C to 3.5mm Adapter CONMDEX Hi-Res DAC Headphone Jack Type C to 3.5mm Audio 2 689828481460 | eBay
Nothing I would hold my breath for anyways.
Those USB C headphone dongles vary enormously in quality it seems. I'm going to try a "diy" ish one - the codec (DAC+AMP) is CS42L42 and USB receiver is SA9302. It's fingernail sized stuff. The package is Savitech ST2213. Specs seems similar (but not as good) to that Adapt Standard and the CS part looks decent enough with max 98dB THD+N into 30ohms and 114db dynamic range. We'll see... Musiland MU1 has the same codec I think for US$35 Musiland MU1 TYPE C portable sound card Earphone cable 3.5mm Headset Adapter decodes for mobile phone-in Sound Cards from Computer & Office on Aliexpress.com | Alibaba Group .
The sellers of those boards often quote the manufacturers ratings of the chips, and that rating was done by the manufacturer using a much much better power supply than what a USB port will provide.
If the raw chip was touted to have certain specs, being sold on its own, then those numbers would be believable. There is a reason that there is a section here on the forum where power supplies are discussed at great lengths.
Couldn't agree more. Although a caveat - the latest regulators are very good at blocking HF noise, e.g. LT3042, TPS7Axxx etc. Doubt there's anything that good in these devices tho.
The above device has isolation on the USB data lines but not the power. The regulators are SV1L813 of various voltages, and there is a buck SV1D3020. I haven't Googled them yet. It's not like I could replace anything on this PCB. I may even have trouble attaching wires it's so small but it would be interesting to know their specs anyway.
It's working..... it wasn't that hard to add wires into a 3.5mm plug so I can use a portable amp with it. It'll do 96/24 and sounds fine - detailed with only very slight mush of fine quiet treble, decent control of sibilance, neutral vocals, very punchy bass. The only fault so far is a tiny faint "tick" noise when the first track starts. For US$8 plus an old cable, a drop or two of hot glue and shrink wrap it's definitely a bargain. I haven't tried it with a usb isolator or cleaner power - just into an adapter to use on my laptop. And I haven't tried it direct into headphones - I need a socket to socket adapter to try that, which I don't have. I'll trim down the strain relief at some point if it gets annoying.
AFAIK Savitech is focused on bulk sales to corporate customers in China so it's hard to find someone selling their products, never mind distributing their documentation. Nightmare for diyers basically, which is shame cos their chips are really good. The SA8804 spdif to i2s receiver has 15ps jitter which is the lowest I've seen of any chip available. Good luck buying one though. For this USB C dongle, the CS42L42 datasheet pdf from Cirrus is all I needed anyway. CS42L42 | Cirrus Logic I got this dongle from this seller on Taobao, which is effectively a China-only shopping site. ??-HIFI ???????-???
I suppose with usb 3.0, there is a 1 amp supply available, so that may help things. I know that my thumb drive plays better from those ports vs the others.
I saw this, has an inductor on the incoming power it looks like, makes me wonder how it sounds.
Mini ES9018K2M ES9018 USB DAC USB Sound Card For PC Cell Phone,Headphone Output | eBay
I've got this one - it sounds good when running on dual rail supplies (TPS7Axxxx) with an OPA2211 op amp. However, it has no USB so it'll cost significantly more overall.
ES9018K2M I2S/IIS DSD Digital Audio DAC Decoder Board Support 32bit 384k | eBay
And this one looks like it might be worth a try too.
SA9227+PCM5102A 32BIT/384KHZ Asynchronous USB DAC/HIFI Sound Card Decoder Board 520516294552 | eBay
I have been using some DIY DAC based on PCM2702 for ages - now I am looking for some better dac for Raspberry or PC. I have found some I2S DAC PCM5102
PCM5102 DAC Decoder I2S Player Assembled Board 32Bit 384K Beyond ES9023 PCM1794 For Raspberry Pi-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
Do you think it is worth buying or you recommend sth different like ES9018 dacs ?
Hi baszek,
If you are willing to do some work, we are modding 'ES9038Q2M boards' into exceptionally good dacs over in the thread here:
https://www.diyaudio.com/forums/digital-line-level/314935-es9038q2m-board-295.html#post5572649
Some people are using the modded dacs with RPi, although they can be used for anything.
I am using this board with a 12s arrangement;
HIFI AK4495SEQ+AD827 XMOS U8 USB Decode DAC board support 32BIT 768K DIY Audio 926319275512 | eBay
It did take replacing many parts to get to a point where I am quite happy with it. I used it with the onboard usb input for a while before abandoning that and tapping into the 12s.
I noticed this board, which appears to have decent parts in the right places, however I have no experience with it, and have no idea whatsoever if it will satisfy your taste.
2018 NEW ES9038Q2M+SA8804 Super DAC Board | eBay
I am not sure if I will have time to mod DAC, plus read 300 pages of posts. I am more into ready to GO DAC - I just want to enjoy music.
Nobody reads 300 pages of posts, and happily it is not necessary. We have condensed down essential information as new people have joined in. However, I understand about not having time to mod. It is time consuming, no question there.
I see that those dacs need external power adapter - can you recommend sth what can be powered with 5V USB or gpio - I am rather searching budget solution for less than 50$ - It might appear that my pcm2702 is not so bad I will try to show you a photo tomorrow.
I pretty happy with my dac sound but someone told me that 2702 chip is history right now and I should take a look at new dacs...
This DAC has had a recent price reduction. Excellent DAC for its small price.
HiFime Tiny Type-C DAC
It is good as is, and very good with a small external headphone amplifier.
There are many plans about for building a such an amplifier at a minimal cost.
- Digital Line Level
- USB Audio DAC worth buying?
