I have tried to find full specifications and application notes for the SA9227 USB to S/PDif but so far without any luck. I've even tried other search engines than Google! - does anybody know if it is available and if so where/how?
Any help would be greatly appreciated.
PS. The best I've been able to find i this one: http://download.esm-cn.com/ATTACHMENTS_201408_101635_20140829860_pdf/SA9227-v1.3a.pdf
Hans Jørgen
Hans Jørgen
Still interesting about SA9227 ? There is either schematics in Altium format. http://bbs.hifidiy.net/thread-1121117-1-1.html
I have Altium installed, so I can to export PDF if required...
You are welcomeThank you very much indeed!
anyone know where to buy SA9227 chips
Free shipping 10pcs / lot SA9227 support 32BIT / 384KHZ / DSD / asynchronous USB DAC chip-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
Well, I'll ask also ))) Anybody know, how to connect an ADC PCM4222 to PC via USB, using SA9227 or either similar IC ?
You are welcome
I rather looking for official distributor or reseller . The purchase was in Europe will be ideally.
SA9227 has pins for connecting ADC by I2S bus -> ADDAT,ADSCLK,ADSYNC,ADMCLK or S/PDIF -> SPDRX.
S/PDIF or I2S input port must be enabled in SA9227 configuration.
Configuration of SA9227 is stored in external EEPROM.
JarekC
You are welcome. The PSU schematics attached.Tolik
Could You be so kind to convert and post
- Digital Line Level
- SA9227 application notes
