The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillator
Thread Tools
Old 13th June 2021, 11:22 AM   #3901
Thom is offline Thom  Sweden
Originally Posted by gionag View Post
one or two things that may be worth checking.
better to switch the coil with positive voltage and keep one side grounded.
the positive side can be bypassed with a cap also to gnd.
that ensure a path towards ground and let the coil act as a shield.
an RF relay, while more expensive, can ensure proper impedance matching.
I confirmed today that the grounding of the coil indeed makes a big difference
the sine in was 11.29 MHz, 5.5 Vpp
with open relay, on the output I measured:
coil not grounded, 7 mVpp (58 dB isolation)
coil grounded, 0.3 mVpp (84 dB isolation)
Old 13th June 2021, 12:10 PM   #3902
Joseph K is offline Joseph K  Hungary
Nice.
Then, just wanted to signal, that Anders Wallin has an open hardware project of an 8 channel RF mux.
Maybe worth a look. And, for people for ~ABX testing like Doede, could serve as it is!
Projects / RF Multiplexer 8ch 1GHz * Open Hardware Repository
Old 13th June 2021, 12:36 PM   #3903
Thom,
I see from the waveform that You are doing it un-terminated.. Maybe it would be, generally better to use Andrea' s clock always properly terminated.
Then, if it is 5Vpp unterminated.. that seems a bit low for me.. Maybe Andrea can correct.
Old 13th June 2021, 01:07 PM   #3904
Hi Joseph,
Thanks for your comments. Don't know if I understand you correctly but the signal is now terminated with 100 ohm to ground when relay is open (would be better with 50 ohm resistor perhaps?)
Old 13th June 2021, 01:20 PM   #3905
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
Yes, it should terminated to ground with 50R.
Old 13th June 2021, 01:28 PM   #3906
Ok, thanks Andrea.
Old 14th June 2021, 02:09 PM   #3907
new test,
As suggested here, I soldered a 0.1 uF MLCC between coil pin and ground plane at the 3.3V side at each relay and re-measured, and this gave nice results, direct coil grounding not needed anymore I think.
I measured only 0.16 mVpp leakage in the best case.
I changed termination from 100 to 75R (did not have 50R at home at this time) and the waveform looks better. Something that looks like approx 100 MHz is riding on the waveform, picked up from something nearby I guess?
Old 15th June 2021, 12:12 PM   #3908
gionag is offline gionag  Italy
Originally Posted by Thom View Post
new test,
in my experience, one side solidly grounded and the other bypassed by a cap performs best.
By switching the coil "high-side", extra care (filtering) must be taken on the psu that act upon the coils (if shared with other electronics..)
but mileage may vary based upon the type of signal/relay/layout.
Old 16th June 2021, 09:19 PM   #3909
Yes, that makes sense.
I have tested the switchboard + STS-DX squarer board in my DAC now. Input is Driscoll 11 and 12 MHz + doublers. Sounds good, will make some listening comparisons later when the build is more final.
Output from the squarer mounted in DAC looks like this.
Old 19th June 2021, 11:39 AM   #3910
minionas is online now minionas  Lithuania
I recently received my 5/6mhz Drixo plus doublers to have final 11/12mhz. Powered it with 16V Andrea's TWRPS-pp.
Earlier i had 45/48mhz Crystec 957 and Andrea's Driscoll v1.
To imagine better: jump of sq from Crystec to Driscoll was less prominent, than Driscoll to Drixo.
Most obvious: better resolution with more details and stronger bass. More focus needed: bigger space, fuller sounds extension, less strain, better PRaT. Just less digital, more natural music reproduction.
Im happy Big thanks to Andrea for developing such fine products! It was worth the wait!
The Well Tempered Master Clock - Building a low phase noise/jitter crystal oscillatorHide this!Advertise here!
Thread Tools
low jitter crystal oscillator IC beta tester needed. yizhou Digital Line Level 4 28th April 2013 05:13 AM
Circuit wanted for a Low Phase noise 100MHz Clock JohnW Digital Source 58 26th June 2012 08:28 AM
New Ultra Low Phase Noise Oscillator from Crystek wktk_smile Parts 7 25th August 2011 07:16 AM
Low jitter 30MHz crystal oscillator? Kuro Parts 2 1st April 2010 12:27 AM
Tube Crystal Clock Oscillator poynton Everything Else 3 25th August 2008 05:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
