Actually TLs are quite tolerant, particularily if you go towards bigger.
Your folding is perfectly valid. I probably have almost exactly the same line in my CAD drawings somewhere… the stub at the bottom is a nice touch to get the terminus exiting on the front, as well as increasing the complexity of the bracing.
The driver is going to need to be about a third of the way down on the front/vent face. There is an optimum Zd.
dave
dave
Thanks for the info! I will be building it next week.
I have simulated it, yes, the driver will be 66cm from the vent and the tweeter is going to jammed right in between the driver and top or under the woofer. I have not heard, how it sounds if the tweeter is that low, so I cant decide, yet
