Class D Amp Photo Gallery
Class D Amp Photo Gallery Please consider donating to help us continue to serve you.
Old 21st June 2019, 06:33 AM   #1411
Nenola is offline Nenola  Finland
Finally got my class D 2.1 amp assembled. Inside two TPA3118 boards with gain mod for main channels, one TPA3116 mono amp for subwoofer and a Wondom DSP. Power supply is 24V 5A.
I got frustrated with the poor quality of pre-assembled 2.1 boards and decided to go this way. Of course the costs are bigger, but I'm very happy with the result. No hiss and only a little bit audible whine when not playing music. Might be the supply, need to do some research if I could lower the noise.
Old 21st June 2019, 11:54 PM   #1412
enio nery is offline enio nery  Philippines
i got the same board for my very 1st class d amp. the psu is a little overkill
still waiting for the tube buffer,relay and the bluetooth receiver so i can start working on it.
Old 28th June 2019, 09:57 AM   #1413
chermann is offline chermann  Austria
+1
@ noise...try the cables separate and short as possible
Old 29th June 2019, 03:41 AM   #1414
Turbowatch2 is offline Turbowatch2  Germany
You know you have to use rectivier and capacitors and this will give about DC=AC x 1.45?
18 volt AC will be quite much for this chip.
Old 29th June 2019, 05:41 PM   #1415
DUG is offline DUG  Canada
DC=18 x 1.414 -1.2 = 24.25
no problems even at 10% high line voltage.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 29th June 2019, 05:47 PM   #1416
So I start with a TPA3251/3255 pcb, a front end for it and heatsink sliced from a computer heatsink.
Old 29th June 2019, 06:08 PM   #1417
Put on some parts and mount to the bottom plate of a Hammond extruded box.
Old 29th June 2019, 06:14 PM   #1418
And put the whole thing together.
Old 4th July 2019, 10:06 AM   #1419
Originally Posted by chermann View Post
+1
That would probably be worth a shot. The wiring as it is, is probably the worst possible with power and signal wires mixed and crossed
Output relay with a delay would also be good, I'm having quite a thump when powering on and off. I could use the mute on TPA3118s but I think it's not accessible in the TPA3116 board. But no room for that kind of additions
Old 4th July 2019, 12:06 PM   #1420
Hi
i use a small "coax" cable for the imputs
yes at this compact size its a problem to fit everything
chris
Class D Amp Photo GalleryHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
