Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Class D Switching Power Amplifiers and Power D/A conversion |
Thread Tools |
#31 |
Hi Subwo1,
I have not simulated yet, but I have a gut feeling that your added 10R resistor will have a rather high power dissipation. Hi Analogspiceman, thank you for posting simulation files. I agree with Subwo1, much food for thought. I would also be interested in simulations using averaged models. So far I have modified some Ispice buck and boost stage averaged models to classD totem pole stage averaged model. But my model is only useful for constant frequency PWM. Bruno proposed method for devising UcD averaged model, but since it has been some years back when I played with Ispice models, I would have to relearn everything back. Best regards, Jaka Racman |
#32 |
Hi Jaka Racman,
Thanks for the viewpoint. I will be very interested to learn what you find out. Best Regards.
USMPS http://groups.yahoo.com/group/switchmode/ |
#33 |
Hi Subwo1,
quite simply, 470nF at 20kHz has 16.94Ohm impedance. So it is a kind like Zobel in IcePower modules. At fully driven output (44Vpeak) at 20kHz you have 25W dissipation. Like it was said in IcePower thread, it can be OK for music, but not for testing. Best regards, Jaka Racman |
#34 |
Hi Jaka Racman,
I was wondering if you remembered that the 10R resistor in series with the capacitor raises the impedance to 27 ohms. Then, I come up with 11 watts. It is definitely not useful for high power applications. So the advantage of leapfrog for efficiency seems good. Thanks for taking a look at it. Best Regards.
#35 | |
![]() Bruno's method seems sound in principle although he may have gotten some of the details wrong. The same method is used for analyzing digital gate driven low level, phase shift and crystal oscillators. There, as with UcD, there is a gross over abundance of gain until the output stage is limited by saturation. If everything is symmetrical then the output will become a square wave. Its fundamental Fourier component is in phase with an rms value of 0.9 times the dc supply (for plus and minus supplies). Follow the loop around through the RC phase shift network (or crystal, or UcD's LC filter) back to the input of the gate (or power stage) and sine wave that shows up is always precisely what is required for unity loop gain at the oscillation frequency. Saturation makes it self adjusting. Ah, but stable oscillation requires more than just unity loop gain. It also require precisely 360 degrees of phase shift around the loop, and that only happens at one frequency determined by the feedback network and the gate or power stage delay. The UcD starts out with 180 degrees of phase shift because due to feeding everything back into the inverting input. Add the nearly 180 degrees from the LC filter and, whoops, we're in trouble because we are very close (but not quite at) the conditions for oscillation. Not good - lots of ringing and who knows what random extra bit of phase shift will put it over the edge and where it will oscillate. Bruno's bit of genius ![]() ![]() So, loop gain at the oscillation frequency is just the transfer function of the LC output filter plus feedback network, but what is it in the audio band? Just as with a typical sawtooth PWM modulator, one need only look at the slope of the wave form appearing at the input (a small sine wave) to the comparator / power stage and calculate how much change it would take along that projected slope to go from zero output to full output. It turns out that it would take a change of 1/4 the period of oscillation to saturate the power stage along this slope. So if we know the frequency of oscillation and the size of the sine wave appearing at the power stage's input, we can calculate its slope at zero crossing (the point of switching). From this and the voltage of the power supplies and the gain factor of 1/4 the switching period, we can calculate the small signal gain within the audio band. This is essentially Bruno's method, but I think he calculated a typical UcD design audio loop gain of over 400. When I work through the numbers for the UcD schematic I posted, I get a much lower number, somewhere just under 60. The devil's in the details, eh? ![]() Regards -- analogspiceman |
#36 | |
Howdy,
Good analysis. Quote:
![]() Cheers, Bruno PS: More precise analysis shows that in this sort of phase-controlled circuit, loop gain at the switching frequency always ends at -6dB. The rest of the curve follows. |
#37 |
Subwo1, sorry I goofed but I did not have my old HP71B calculator at hand. Analogspiceman, I was hoping to see more comments from other members. Right now, LF is very appealing to me since it can also work with fixed frequency control. Recently I discovered US patent 4479175 which has now expired. It renewed my interest in ampliverters. Since they work constant frequency, UcD control is out of the question. I have three questions: -do you think that for fixed frquency operation, average current mode loop could be used with equally good results as it is possible with hysteretic current mode control? - what do you think about curent sense method that integrates output inductor voltage instead of using direct sensing? I know that inductor saturation could be problematic, but what else ? -do you think that LF method could be improved by summing output of voltage error amplifier with differentiated input signal (capacitor current feedforward like in Mueta) Best regards, Jaka Racman |
#38 |
Hi Jaka Racman, it's quite all right. I appreciate that you took a look at it. Thanks, regards.
![]() PS. There is a calculator in Windows Accessories. Under the view tab, there is an option for scientific notation.
#39 | ||
Yes, I probably misread something somewhere, as I am getting my information about the UcD180 design all second hand from back threads, other posters and guesses. By the way, I went through the math regarding the two loop gains, and you are quite right, taken against each other everything drops out except a factor of two (at least at 50 percent duty cycle and as long as the signal appearing at the UcD input is more or less a sine wave). Delays in the power stage (or right half plane zeros) eat your phase margin without giving back more loop gain, so a responsive power stage with a 3rd order type circuit would be best. Because this is a phase controlled, gain saturating oscillator, it might be difficult to get an even higher order, higher gain, marginally stable system to start up reliably oscillating at the right frequency. Oh, well. Depending on what's driving it and how the inputs are configured, the UcD might need something (couple of diodes) to keep the input BE junction from Zenering. Also, with mosfets that need it (or to limit EMI), you might find my simple drain-to-gate RC dv/dt limiter useful, since the UcD is already set up perfectly with asymmetrical drive (its got the pull-down PNP that the RC needs so it only affects turn on dv/dt). I'm very impressed with the UcD's elegant simplicity most of all. I like it (please tell Jan-Peter that if you get too busy with other projects, I'm ready to step in). ![]() Quote:
A friend of mine actually made a working inverter using that phased carrier concept. It works fine, but can be difficult to snub simply. In the end, he decided it was more costly than traditional approaches. Three Q's: 1) probably, but comparing theoretical bandwidth (after correcting for hysteresis control's wildly varying frequency) would be very interesting. 2) Risky. Loss of tracking during saturation could be a disaster and thermal resistance shift in the wire would be problematic. 3) ??? Leapfrog already feeds forward the output capacitor's load current. Did you mean something else? To Subwo1, Actually you stole a little bit of my thunder. I was going to mention the output damper as a possible addition to the UcD to cure its transient ringing, but Jaka already covered the down side of that. Note that with most loads, it wouldn't be a problem anyway and it might be better just to step around the "problem" by limiting the input signal appropriately (I know, some people don't like such circuits, but it is much easier to do it colorlessly on the low power input than on the high power output). By the way, from the power supply world, the standard recommended Q killing RC damper is 3*C and R = sqrt(L/C). Regards -- analogspiceman |
#40 | ||
![]() Quote:
Actively peak track and low pass filter the lowest points of power supply ripple. Further reduce this by a signal proportional to mosfet current (compensates for IR drop). Scaled down just a bit, this then becomes a moving reference for an input limiter that always allows maximum possible output power (with no hum during "clipping"), and without ever having the output stage actually saturate and suffer the ill effects of opening the feedback loop. Regards -- analogspiceman |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
on the job teaching methods.... | unclejed613 | Everything Else | 1 | 12th April 2009 10:39 PM |
Quiescent Current Control in Class AB..? | xitronics | Solid State | 27 | 25th September 2007 02:37 PM |
nrg control stereo class A amp | jfrago | Solid State | 0 | 8th June 2007 05:41 AM |
How many modulation methods in Class D amplifier ? | xuhaoz | Class D | 20 | 5th December 2006 05:15 AM |
water methods | PWatts | Multi-Way | 0 | 25th June 2003 11:46 AM |
New To Site? | Need Help? |
