Sabaj A20a modification... worth the effort?
Thread Tools
Old Yesterday, 09:01 PM   #51
douede is offline douede  France
I guess everyone checked the settings before posting about the sound...
Old Yesterday, 09:04 PM   #52
SoniCCurrent is offline SoniCCurrent
Originally Posted by douede View Post
Hummm...submiting (bias) or operating a lytic cap at its rated voltage is no good for its lifespan nor regarding distortion/linearity (see Cyril Bateman investigations).
Where do I find those Bateman investigations, do you have a link?
I believe as long as you stay below V+7% you should be fine. 26V should be ~4% therefore okay, as long as there is not much heat in the case and as long as the ripple does not get too high. Since I swapped the PSU with a RPS-400-24, there should be notably less ripple coming to those caps, for it's great in those terms. Therefore I should be safe (I figured) using 26V.
https://www.mouser.com/pdfDocs/UCC_E...nicalNotes.pdf
5-6-1 Overvoltage shows 107% WV has small effect and 114% WV much more on lifetime.
Old Yesterday, 10:05 PM   #53
Jogi is offline Jogi  Germany
I had to check it every day from time to time, because it just changes without me doing it. I think it's a bug.
Old Yesterday, 10:17 PM   #54
Well, had hard time googleing "Cyril Bateman capacitors" led me to the first link : Cyril Bateman's Capacitor Sound articles | Linear Audio NL
Old Today, 02:01 AM   #55
This is what I don't understand. The new MA12070 amp from Topping does not seem to have 2200 FK caps at all, but only 470 35V caps, Link, just as the DIY boards you can buy from audiophonics, just as the reference-board from infineon.
Why do they use those instead?
  Reply to this post
Sabaj A20a modification... worth the effort?Hide this!Advertise here!
Thread Tools
Sabaj D3 Asio tony.garner Digital Line Level 2 23rd July 2020 06:19 PM
Sabaj DA3 Dual ES9018Q2M DAC Internal Pics wushuliu Digital Line Level 3 30th October 2017 11:50 PM
Is it worth the effort? reticent67 Car Audio 10 6th July 2004 04:53 AM
Is this mod worth the effort? clevegilbert Tubes / Valves 2 27th January 2004 01:23 PM
"Angling rings"... worth the effort? eRiCdWoNg Multi-Way 16 4th August 2003 09:50 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
