Hello, i have buyed this amp.
Amp is in Protect. LED lids only very weak red. Obvisiosly no parts are damaged. If i ground Pin3 from TL 494, the amp powers up and produces rail.
But its not stable.
The Output from TL 494 goes for each bank on a MC34151. ,
The first seconds everything is ok, then the Amplitude out of the 34151 starts drop a little bit and the frequency changes.The VCC Pin 6 is also going high and low a few volts all the time. If remote is connected, i have 9V, if i ground Pin 3of 494 it drops between 6-5VDC.
I have removed the Audio driver board, and the outputs from the 7912CV and 7812CV because the got hot. Still the same.
Found also, that on Pin12 of the 494 is with remote applied only 9VDC
With the Audio driver board inside i have no DC on the Outputs. But also no Oscilation on the Output fets.
Any suggestions?
But its not stable.
Any suggestions?
Pin 5 goes to the Protection Board close to the relays.
Pin 7 goes over a diode to a resistor, than optocopler to pin 1 of 494.
If i remove the protection board, the amp switches on, but the relays dont engage.
So i think this is dc protect and the power supply for the relays.
- General Interest
- Car Audio
- Eyebrid 1y2000 Problem
