Eyebrid 1y2000 Problem
I havent checked with the audio drive board. Now with the drive board inside, it goes always in protect, and no gate drive. If i leave the remote connected, it stays in protect and switch to on for half a second, than back to protect. I think there is also a issue with the audio board. I dont now which drivers are mounted, because they removed all markings.
Continue. Received the new parts. Installed the new Voltage regulator. Tryed to start without the IR... Directly a resistor start smoking. This resistor is a 8Ohm, in line from the output of the Regulator. Goes to the IR Pin 3 on the board. Passing a Zener. Removed the Zener and checked with diode test. from each side 095 measured. So i think its broken. Any sugestion wich value this zener has?
