Simplistic NJFET RIAA
Old 2nd September 2014, 10:33 PM   #13391
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
My calculations for 30v are 30 /230 *240 = 31.3VAC * 1.41 = 44.1VDC less diodes etc.
A 33 VAC Tx comes out at 48.5 VDC. Hmmm
Lucas
Old 2nd September 2014, 10:49 PM   #13392
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
But the Airlink 230/30+30 gave 46.5+46.5VDC because we barely load it to its true current ability. I would order same secondaries and VA model from same manufacturer as Marra if in your shoes. Because all unknown factors are already tested. I would only ask them if they offer magnetic shielding peripheral band as an extra option.
Old 2nd September 2014, 11:09 PM   #13393
Originally Posted by stajo View Post
Thank you. Indeed it is to be a DCB1 buffer preamp with the FSP as integrated RIAA. Akouo select & volume with a Muses 72320 chip.
It doesnt show at the pic but the boards are actually piled up to the final height so the legs are about right. Ill solder them when its fixated.
I am to fodder the alubox with thin ply and fodder the heatsinks even more so they only radiate to the outside.
The DCB1 will have its own foddered compartment with heatsinks with the same principle.
Plus a separate PSU box with a lot of different voltages in the umbilical cord connecting the two.
Stajo,
It looks like a very practical solution. My only question is, if you are to have a separate power supply unit feeding the unit by an umbilical, isn't it better to bring DC into the pre-amp with the umbilical, rather than AC? The DCB1 has onboard rectification. Are you planning to move the rectification off the DCB1 board and into the PSU box?
Lucas
Old 2nd September 2014, 11:20 PM   #13394
My matched pairs of 2SK170BL are as follows:
6.60 mA pair
6.89 mA pair
7.07 mA pair
7.39 mA pair
7.47 mA pair
7.52 mA pair
7.62 mA pair
8.12 mA pair
They were, however, all tested with 9v, back when building DCB1, F5, etc.
I also have a near match at 9.80 / 9.96, which when I retested at 22v, came out at 10.31 / 10.50 which shows that voltage is critical to evaluating IDSS.
Should they all be retested please, and if so at what voltage?
Lucas
Old 2nd September 2014, 11:53 PM   #13395
Salas's Avatar
Use 10V for your re-testing confirmations if you got a variable PSU. Leave each one sample enough minutes on power until it stops climbing on the reading.
Old 2nd September 2014, 11:56 PM   #13396
OK. Yes they can sometimes climb for about 5-10 minutes as I remember, which complicates testing. Doesn't the actual voltage they will encounter in the circuit matter though?
Lucas
Old 3rd September 2014, 12:29 AM   #13397
stajo is offline stajo  Sweden
Originally Posted by LucasAdamson View Post
Stajo,
Yes. I make a pre reg filter C-R or C-L in the PSU-Box and plug directly on to the onboard C.
Old 3rd September 2014, 12:30 AM   #13398
Salas's Avatar
Practical test:
10V K170BL 7.48mA (3 minutes are enough)
9V same sample 7.44mA
They will not encounter more than 9-10V VDS in circuit.
Old 3rd September 2014, 10:33 AM   #13399
Marra is offline Marra  United Kingdom
Originally Posted by Salas View Post
That's nice bcs the Decca is peculiar. So, given the trafo was loaded, it should have about 1.35 full wave rectification ratio DC/AC in this app. Is it 80-100VA rated model?
I went for the 120VA as it was only a couple of pounds difference and added an interwinding screen.Didn't bother with the Goss band as the power supply is in a separate case so I didn't think it was necessary.
Old 3rd September 2014, 12:37 PM   #13400
R.I.P.
Originally Posted by Marra View Post
Will do once I sort out photobucket.
Attach your pics.
regards Andrew T.
Simplistic NJFET RIAAHide this!Advertise here!
Copyright ©1999-2019 diyAudio
