Graphic Equalizer induces noise
Graphic Equalizer induces noise Please consider donating to help us continue to serve you.
Old 8th October 2019, 12:17 PM   #11
sgrossklass is offline sgrossklass  Germany
Originally Posted by PhantomBox View Post
I know, I made an apprenticeship in Remscheid at the time and saw the whole thing on TV.
Then you must be about a decade older than me. How'd you end up in Venezuela of all places?
I checked the EQ again today and noticed that the 1.25k frequency in particular is the one that induces the noise. There is something that looks like a polyester cap but say "133H / 100V" on one side (no idea what this marking means) , followed by a 1K ohm resistor and one side of an 4558 op-amp. I'm not such a good electrician as to figuring it out right away. Could you give me a hint, maybe?
I'm not exactly an expert on EQs but would check for dry joints on Rs and Cs involved in this range, and check whether the resistor hasn't gone high or maybe even a cap gone open (as rare as it is).
133H is 13 nF, 3% tolerance. (133 = 13*10³ pF, H = 3%) 100V is the voltage rating.
The schematics of EQs I've seen had one opamp and a lot of RCs. Is this also the case here or is it a fancier circuit using one OP per band? Unfortunately I can't remember for my life what make/model they would have been, otherwise I would have looked it up. Ah, looks like Yamaha had a bunch. Probably not a great deal of variation between models. I imagine you could replace the transistors with opamps.
If that's not it, maybe it's more like ESP P64 or P75.
Old 8th October 2019, 04:20 PM   #12
PhantomBox is offline PhantomBox  Venezuela
Mein Vater hat für ein deutsches Exporthaus jahrzehntelang so ziemlich jedes südamerikanisches Land bereist. Als er dann die Möglichkeit bekam, sich in irgendeinem Land niederzulassen entschied er sich für Venezuela, da es hier gegen 1981 politisch und wirtschaftlich noch am stabilsten war. Ich war damals 13 Jahre alt. Dann kam hier - ich glaube 1983 - so etwas wie ein Black Friday, und die Währung wurde abgewertet. Eigentlich kein Problem. Bis dann 1991 der Chavez erst einen missglückten Putschversuch machte und dann demokratisch an die Macht gewählt wurde. Der war ein Militär und Sozialist (parallelen zu historischen Figuren sind rein zufällig) Dann war es hier eigentlich auch aus mit Business...
Ich kann dir ein paar Fotos vom Innenleben des Equalizers senden.
Old 10th October 2019, 11:27 AM   #13
Tja, dumm gelaufen. Als ich in dem Alter war, sind meine Eltern "nur" von Berlin in die württembergische Provinz gezogen, das hat auch noch gereicht...
That's a whole bunch of opamps. 17 duals for 31 channels, wonder what the "overhang" is doing.
Hmm, flex cable... another possibility for bad solder joints.
Old 10th October 2019, 12:58 PM   #14
Ce la vie...
I guess it was an opamp. I switched the original 4558 for another 4558 (and a socket) and the noise almost disappeared. Then I tried a 5532 and finally a 072, in my opinion they are much quietest of them all. I will leave it that way.
I still haven't found a schematic for this eq.
Old 10th October 2019, 03:28 PM   #15
indianajo is offline indianajo  United States
indianajo's Avatar
4558's are almost music quality op amps. Maybe good enough for a punk garage band.
I've picked up 4 different odd brands of graphic equalizer for $10 at a charity resale shop or later off the curb on garbage day. No chance of schematics of any of them. Everybody was making them in the 80's. I've used the power switch & aux 2 pin AC socket out of one. You can't buy 2 pin AC anything, your fire insurance company might sue the vendor. I might actually repair the 5th equalizer, a Peavey whose filter caps hum.
After watching DW news with subtitles enough I might understand post 12 & 13. I earned a D in college german 101.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 15th October 2019, 06:24 PM   #16
ndcraig is offline ndcraig  United States
Hi guys.
I have an older DOD 831 Series II graphic equalizer that induces noise (shhh) as soon as I increase or decrease any frequency band, the more I move the fader the more noise comes out.
Any Idea of what might be happening?
And I cannot find any service manual for this EQ online.
Thanks in advance.
DOD were exceptionally noisy ("hissy") even back in the day when new.
They were low cost affordable units and not considered high quality.
Your unit is probably getting quite old by now and may have failing components.
Analog pro audio gear is readily available nowadays thanks to digital mixers making it all obsolete for pro users
and if you ask around you can probably find a better quality used unit for very low cost
Graphic Equalizer induces noiseHide this!Advertise here!
WTB 31-band graphic equalizer Dave Jones Swap Meet 2 13th December 2010 09:31 AM
5 Band Graphic Equalizer NSLogan Chip Amps 2 17th June 2009 04:52 AM
DIY Graphic equalizer? coldfuzion76 Solid State 4 18th March 2008 09:45 AM
Graphic equalizer Buzzy Parts 1 24th July 2007 08:55 PM
Graphic Equalizer Johnny25 Parts 5 29th March 2006 06:33 PM
Copyright ©1999-2019 diyAudio
