LDR Pre MkII - LDR volume control and I/O switching
Thread Tools
Old 12th May 2021, 05:51 AM   #361
zdr is offline zdr  Belgium
zdr's Avatar
It seems to me that your OLED is drawing too much current which brings down the voltage on Nano supply line, or you have a parasitic resistance somewhere along the power line.
1) Connect OLED to separate (LAB) 5V power supply and check how much current it draws.
2) When OLED is connected, is 2.02V consistent throughout the 5V line starting from 7805 regulator, or is there a voltage drop somewhere along the line? If you have 5V after the regulator and 2.02 at VCC on OLED, you have a resistance somewhere along the line.
Custom DIY PCBs, BOM and LDR Firmware:
https://sites.google.com/view/dacgear/
Old 12th May 2021, 06:28 AM   #362
EfkaIII is offline EfkaIII  Lithuania
Originally Posted by didiet78 View Post
I think you have problem on vcc oled
Do you mean that voltage on LED VCC supply line should be 5 VDC ?
Old 12th May 2021, 07:05 AM   #363
1-> The current of OLED power is 4.1mA
2-> When OLED connected the 2.02V DC is on terminal OLED VCC or main board point VCC. All regulators 7805 gives on output from power supply up to main board 5V DC.
Without schematic I`m "in dark forest at night"....
From where VCC to OLED is powered ? I found O+ and OLED VCC is the same, but this power terminal "O+" option is not used as I understood
Old 12th May 2021, 09:11 AM   #364
zdr's Avatar
Ok, I think I know what the problem is. You have a latest mainboard PCB which has separate O+ power for OLED, but that one is not connected as you don't have OLED (O+) output on PS board. You need to connect R+ and O+ lines to supply OLED with power.
Old 12th May 2021, 09:18 AM   #365
zdr's Avatar
You can put a short wire between R+ and O+. In case OLED needs more power, you can try D+ instead of R+.
Old 12th May 2021, 09:40 AM   #366
Yes I understood when talking starts regarding 5V DC VCC.
You need to update your manual
Old 12th May 2021, 01:45 PM   #367
Next step regarding ERROR 10:
I would like to double check :
1. acc. attached picture LSE and LSH (another "Right" channel will be similar) are in this places with check points on PCV (right upper side) v. 1.31?
2. If the 1. is OK, then after adjusting BIAS (700k /next time 750K for double check) and after setting in "Parameters menu" LSE/LSH/RSE/RSH minimum resistance (for my project 35...37ohm) I can not start calibration procedure - receive ERROR 10.
3. What is a levels in "Show Statistics" : LSEmin/RSEmin/LSHmin/LSRmin? Because theses levels are not the same as I set in Parameters menu.
Old 12th May 2021, 03:04 PM   #368
zdr's Avatar
What is the error 10 text saying? Forget about show stats, nano can never measure Ldrs correctly, thatís why we still use multimeters.
Old 12th May 2021, 03:56 PM   #369
Error 10:
LSE too low
- adjust RT1
Old 12th May 2021, 07:07 PM   #370
zdr's Avatar
Try to reset Nano few times without powering off the circuit, see if that will make a difference.
LDR Pre MkII - LDR volume control and I/O switchingHide this!Advertise here!
Thread Tools
S&B TX 102 MKII Volume Control Transformes wattsman Swap Meet 2 19th November 2018 07:30 PM
Bluetooth switching for stepped volume control? Technical Petting Parts 0 31st January 2018 08:59 PM
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
About volume control and input switching Janne Nivala Solid State 7 15th August 2001 05:50 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
