AKSA's Lender Preamp with 40Vpp Output
Old 9th November 2018, 09:09 PM   #881
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
I know I like 0.05% H2 and 10x less H3 and nothing else. It always sounds better this way. And on a zero feedback SE Class A amp, it will always beat a regular high negative feedback H3 dominant LTP front end based amp in a blind test. But, even an amp with only 0.005% H2 and monotonically descending harmonic profile will beat a H3 dominant amp that has lower THD.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 12th November 2018, 10:47 PM   #882
nzlowie is offline nzlowie  Australia
Hi guys, about to start construction...... can you please confirm the errata data on post 777 and the start of the GB tread is current? Read most of the posts and it looks like everything is covered but I don't want to miss anything.
Old 13th November 2018, 12:29 AM   #883
Got Foam?
xrk971's Avatar
Yes, post 777 is it. If you have questions along the way, just ask here and we will try to answer in same day.
Good luck!
Old 13th November 2018, 07:19 AM   #884
Good luck!
Good luck..... Hope luck isn't required? Just wanted to confirm those changes on 777 are all, once I start soldering not a lot stops me till I'm done!
So as I'm building as a pre not a HPA I can lower the gain?
Thanks, will post if I have any issues during the build. Great to know support is available.
Cheers
Old 13th November 2018, 09:29 AM   #885
Puggie is offline Puggie  United Kingdom
Sorry if this has been covered. but the different daughter boards, is these a difference in performance or is it purely down to preference of assembly?
Old 13th November 2018, 05:35 PM   #886
Got Foam?
xrk971's Avatar
Regarding DB's, it's mostly down to assembly as measured distortion between different ones are about the same. The TH version lets you add a big heatsink and use a 2SA1837 and boost bias current for headphone amp though. The miniMELF SMT version is tough to make since miniMELFs are hard to find in US at places like Mouser or Digikey - they were out of stock on lots of them so go 0805/1206 SMT if you want to make those. Technically, the SMT should have lower noise since parts are smaller and traces shorter.
Old 16th November 2018, 01:33 PM   #887
maf_au is offline maf_au  Australia
Originally Posted by GASCo View Post
These should be final:
MB: Mouser Electronics
DBTH: Mouser Electronics Resistor 2.2K added for gain for ACA.
Thanks for releasing the Mouser component Project lists for AKSA. That will make it easier to buy most of it from Mouser rather than half a dozen suppliers.
Old 17th November 2018, 04:52 PM   #888
Got Foam?
xrk971's Avatar
A new use for this Preamp. Bypass the M2 front end and autoformer for super quiet and powerful amp.
AKSA Lender Pass Hybrid M2 (ALPH-M2) Amp
Old 20th November 2018, 11:03 AM   #889
marconi118 is offline marconi118  Germany
can I use the transistors of the v2.0 for the HV in the regular version?
Old 21st November 2018, 12:11 AM   #890
Got Foam?
xrk971's Avatar
Yes
AKSA's Lender Preamp with 40Vpp OutputHide this!Advertise here!
FS: AKSA GK-1 (EL) Preamp kit kv2 Swap Meet 1 14th April 2017 11:04 AM
Alternative output transistors for the Baby AKSA 55 cs Solid State 10 13th September 2013 10:06 AM
preamp for aksa 55 Professor smith AKSA 98 12th February 2012 12:11 AM
Borbely-Lender True Symmetry steph_tsf Solid State 33 23rd August 2011 12:52 PM
Aksa preamp? rick57 Solid State 11 19th May 2006 09:26 PM
Copyright ©1999-2019 diyAudio
