hi all! new here.i have a question about the swx module it is in both amps,can i use this module for my mids and highs on the zx460?also the module only works for the #2 amp on the zx460.one more thing i was seeing if any has a link to a birth sheet or one thats been tested just want to get a accurate idea what this amp really puts out at 4ohms stereo.the zr 240 is going to be use for my 8" sub or my front speakers BA rc520s they say those rc520 can take 300 watts rms.
thanks in advance
thanks in advance
I have some of these laying about here somewhere, but for now the question is
"Does it have a high low bypass three position switch located about mid board of the module?
If so your stuck using the factory crossover points but yes it will do what you want, and give you factory selected crossover points. If that was what you were asking.
I think there is a guy on ebay still selling some of these by the name of Iameverlast or something like that. Just pm me and I will look him up for you if need be.
I don't know of any birth sheet results being posted anywhere. I do my own with lab gear I have here at my home...hope some of this helped..
swx has two switches, two frequency 'chips'.
first switch is two position, selects amplifier for low or high pass.
second switch is three, select output jacks as low or high pass, or bypass.
'chip' in zx460 is either high pass or bypass...selected by switch next to it.
Mark
Mark
