Zobel effect on LF
The impedance of my 8ohm woofers has these aproximate values:
30Hz: 24 ohm
35Hz: 30 ohm
40Hz: 26 ohm
50Hz: 18 ohm
60Hz: 12 ohm
100Hz: 8 ohm
If I use a Zobel (RC) in the woofer 2nd order passive fileter I can make this rise in the impedance almost disappear.
What results (win-lose) can I expect in the bass from doing so?
You should have measured above 100Hz. The zobel will counteract the rise in impedance due to voice coil inductance, and occurs higher up the band than the impedance peak due to box interaction -- which you have measured there.
As said, it won't change much unless your crossover is around that region. If you have a fussy amp it might make it a bit easier to drive due to it compensating the lagging current.
Between 100Hz and xo point (750Hz) the impedance is stable at 8 ohm.
The bass amplifier is a 3-stage class A amplifier with lots of current that handles well low impedances such as 2 ohm (Pass Aleph 0). It doubles the power with half the impedance - at 2 ohms it delivers 4 times :hot: the power at 8 ohm.
Using the Zobel wouldn't have any effect in the woofer curve response around 20-60Hz?
