Zinamp 3way active crossover
Just wanted to say I've had a great experience using this crossover module from Zinamp http://www.zinamp.co.uk/
Really easy to integrate and power etc. Dead quiet. It's easy to adjust the crossover points on the fly which is really what I was looking for. You can even change the shape of the slope depending on how your driver measures. It has baffle step compensation that you can use or not. Bass boost!
I'm still using the op amps that it came with but there are higher performance ones available
And if all of that wasn't great enough the technical service from the owner or whoever does his tech support has been flawless and so quick.
I guess this might be a review at this point. I just haven't seen many people talk about it on here and I feel like it is a really simple solution. It sounds really great to me
Same goes for neurochromes preamp power supply, super great to have such simple modules out there for those of us who have a tendency to blow things up
  • Thank You
Reactions: motokok and GM
