For Sale Zilchlab Econowave Crossover PCBs
Things you have for sale.
Hello again Wiredbecker. Can you send an updated Parts Express BOM for the Econowave boards? I'd also like to know if there are any suggestions for a replacement for the L2 1.5mH iron inductor 0.126 dcr that will mount on the PCB? The part number I have for the original was 266-552 but no longer available from PE.
PE has a similar 257-652 but it is 0.24 dcr.
PE 257-652
Madisound a similar one with 0.146 dcr
Madisound SI1.5
Please let me know if there is a drop-in replacement for the 266-552 or if either of the above would work. Thank you!
Hi @RickH
Here is my parts list from the last time I built out the Standard Econowave in an Advent cabinet with L2 updates.
<95db/w Econowave Standard Parts List
C1:
Dayton Audio DMPC-4.7 4.7uF 250V Polypropylene Capacitor
Part # 027-422
C2: Dayton Audio DMPC-12 12uF 250V Polypropylene Capacitor
Part # 027-430
C3: Dayton Audio DMPC-0.47 0.47uF 250V Polypropylene Capacitor
Part # 027-406
L1: Dayton Audio 0.60mH 20 AWG Air Core Inductor Crossover Coil
Part # 257-040
or the slightly more expensive
Jantzen Audio 0.60mH 20 AWG Air Core Inductor
Part # 255-040
L2: ERSE 1.5mH 18 AWG I Core Inductor
Part # 266-552 (More expensive, mounts to PCB using mounting hardware)
Which is out of stock now. Go with:
Dayton Audio IC181-5 1.5mH 18 AWG Laminated Iron Core Inductor
Price: $6.59 Part #257-652
or
https://www.madisoundspeakerstore.c...uctors/1.5-mh-steel-laminate-inductor-18-awg/
1.5 mH Steel Laminate Inductor 18 awg
Price: $7.20
I pay a little extra just to be able to use mounting hardware!
or
Dayton Audio 1.5mH 18 AWG I Core Inductor Crossover Coil
Part # 257-552 (Less expensive, mounts using zip ties)
Sadly out of stock as well now.
R1: Dayton Audio DNR-30 30 Ohm 10W Precision Audio Grade Resistor
Part # 004-30
R2: Dayton Audio DNR-16 16 Ohm 10W Precision Audio Grade Resistor
Part # 004-16
L-Pad: L-Pad 50W Mono 1" Shaft 8 Ohm
Part # 260-255
Binding posts: Dayton Audio BPA-38SN HD Binding Post Pair Satin Nickel
Part # 091-1247
Waveguide: Dayton Audio H6512 6-1/2" x 12" Waveguide 1-3/8"- 18 TPI
Part # 270-318
Compression driver: Selenium D220Ti 1" Titanium Horn Driver 8 Ohm 1-3/8"-18
Part # 264-270
Reactions: wwschaff
Hi guys, (mods, please remove if not aligned with the rules here)
I built a pair of Advent Legacy Econowaves a few years ago...they sound great! I am retired now and downsizing my audio gear. I would put these things up for sale, but locally, nobody would know what they were value-wise. Plus I do not want to ship them due to weight, and shipper's negligence. I figure it would be better to part them out and offer up the parts here. Would anyone be interested in some or all of the parts? Zilch board, all PE parts as listed by wiredbecker above. Please PM me if interested and we can negotiate pricing. Thank you!
