Zener regulated supplies
Greetings everyone,
Do zener regulated supplies cause any "noise"? If they do, how would you "quiet" them?
Thanks,
Ray
Depends on how you are using them ?
A small 0.1uf cap across each is normally more than sufficient. Zeners produce broadband noise (very low level) in operation and can actually be used as a noise source if you amplify it as here on page 3,
http://www.n0ss.net/noise_generator_ac7ac-style.pdf
Low voltage zeners ? high voltage ? and how are you using them ? same applies though, a small cap and the noise is gone.
I'm using the zeners in a bias supply. The zeners will be regulating voltage coming from a bridge rectifier.
Ray
