Hi
I have a basic question on the Zen V4 PCB shown in the passdiy web site (Fig 4). There are three contact points shown on the PCB -
+IN -OUT V+
I assume the +IN is the input from the source and is the positive.
-OUT is the speaker output- the question is does this go to the positive or negative of the speaker? Does it matter if I stick to the same order on both channels (as long as the phase is maintained?).
V+ is the 50V power supply connection.
If any of the above assumptions are incorrect, I would appreciate any feedback
thanks in advance
vsr
+IN -OUT V+
thanks in advance
vsr
The "-" speaker out goes to the minus speaker terminal. The "+" in is the hot sigal input. Try to hook up the in's and out's to the correct places, especially if you are bi-amping. If you're not bi-amping, just keep them consistent between left and right, and you should be fine.
