I'm looking at building a Zen V4 and I'm just planning on the power supply as of now. I'm planning on building a stero version, unbalanced, with two Plitron 077014201 transformers. As for capacitors, I'm currently planning to use Sprague Powerlytic 36DYs, as I have a stash of them here. I'm looking at using 8 per channel, for a total of 44,800mfd perchannel. I'm also looking to do point to point wiring, as they are screw terminals, I don't suppose anyone has a recommend wire gauge or type? The connectors I'm using are solder on spades.
I'm also looking at two MECI heatinks, part number 310-0281 for the heatsinking. I was wondering if you guys think this would be enough heatsinking(without using forced air) using the standard bias current(with both R0 and R1, so about 100W of heat will dissipation).
