Zen amp
Here is a slightly simplified Zen amp with a mu/SRPP dynamic current-source based on a simple cheap 9 volt battery (V2).
With two IRFP054 you get quite low THD.
LTSpice says 0.204% THD @ 6 watt output into 8 ohm load. With real speakers and real reactivity in the load I would be happy with 0.5% measured THD. This SRPP-Zen-amp simulates much better then the stock normal Zen-amp.
With slightly higher voltage over the sensing resistors in the SRPP current-source you get less distortion at lower output-power but the amp will start clipping at slightly lower output-power.
M1 and M2 can be IRFP054, IRFP064, IXYS IXFH110N10P Polar mosfet or similar.
I would without a doubt go with the IXYS mosfet. They sound absolutely superior in simple class A amps in my experience.
Johannes
Joined 2002
OK...I just looked at the Zen revisited article and see that
IRF140 and IRF9140 (TO-3 metal can parts) are shown. You can just use the
current plastic package lead-free versions: IRFP140PBF and IRFP9140PBF.
These should be readily available. (The original Zen article actually
listed the plastic packaged mosfets.)
As drawn, the constant current source in the Zen revisited uses a
P-channel part. Please see the Zen Variation 2 article for a version
with an N-channel mosfet and the modification into an Aleph current source:
https://www.passdiy.com/project/amplifiers/zen-variations-2
Dennis
