Here some raw photos of the Very-Pre-Finished version of my Zen # 9...
soon with the photos of the ultimate version:
here the evolution :
What do you think ?
What do you think ?
then, the schematic is on the passdiy site (http://www.passdiy.com/default.html). The amp is in pure Class-A.
It draw 100W per channel and it's power @ 8 ohm is about 15w. the THD figure is impressive and the sound is marvelous 😀
thanks NP for sharing this project !
Looked quickly at the site and no sure if i get the right schematic.
What speakers do you listening on this 15 watt A class?
in fact, on NP diy section the pdf about the zen V9 is missing.
if you want, i can send to you the whole documentation for building your own zen.
send me a pvt msg.
send me a pvt msg.
Hello gionag and jacco!
I saw the pdf on the link jacco was sent, but there is no technical data for this amp., I am interested to see the whole parameters of this amp. like freq. response , thd, slew rate , damping factor, signal to noise ratio, etc..
Also if this is good for me, where I can find the complete art work of PCB design for this project.I already have a toroid transformer about 700VA 35+35 volts wound by myself with 2mm or more diameter of copper wire in the secondary.
By the way can any one tell me more how is the sound of this amp. because I have here Marantz PM 80 which has option to work in A class with about 20 or 25 watts per channel i am not sure if this power rated at 4 or 8 ohm impedance.
Will this amp sounds better than Marantz pm 80 operating in A class.I am also not sure if the Marantz switched to A class works exactly in "PURE A CLASS").
look at the owner's manual of the F3 (on passlabs.com "First watt" Section). The typ. characteristics should be the same.
Ok for the toroid, and i sent to you pcb artwork plus other material via email.
Ciao
Michele
Ciao
Michele
nice italian 😀
the PCBs is from Peter Daniel and Damian Antoniak (i hope that i spell well). i don't remember the thread where the download of those is avaiable.
i'll send you via e-mail.
Thanks 😀
Thanks 😀
Io parlo italiano
Thanks for the zen pack.
Hmmm I hope i can use pdf files.
I was hoping for some gerber-files.
Well, I think I will do just fine.
Thank you anyway.
Thank you anyway.
You would have wanted to have the boards made ?
Other Question : any reason why you didn't cut the PS board in half to save some wire ?
(sorry about the P-joke, me have rotten mood today)
- Zen#9 is arrived !
