This DSP/Amp has 12x 80w at 4Ohm. Bridged 6x 240w at 4ohm. Can i use 2x bridged at 240w for a dual coil subwoofer? So 240w per coil. And the remaining amp power, 4x 80w for tweeters and midrange. 2x 240w for both midbasses. Thanks
That's OK but you need to be sure that you don't get the polarity wrong on one coil. If you do that, the magnetic fields will cancel each other out and the woofer will likely fail (the coil will burn).
