carlos spud said:I want to build a five channel amp any opinions on whether i should go with the zappulse 2.3se or the ucd 400 the lc audio stuff seems geared towards noobs like me a little more. Thoughts, Comments, Suggestions all appreciated
Cheers,Carlos
t. said:Yes, these threads do end up in arguments
It would be nice though to read somebody's results who has compared something like a UCD based amp against a well known commercial or diy classA or AB amp
I'm still tempted to try out a pair of UCD400's , all I want is to build something that sounds better than what I currently have rather than something else that will just add to my collection of tried and now not used stuff
ghemink said:
Some people have reported comparisons. I compared a slightly modded UcD180 with my Accuphase E407, the UcD180 won easily. UcD has a very open and dynamic sound, completely free from distortion, very good imaging and extremely low noise level.
If you have never tried Class-D, give it a try and I'm quite sure you will be happily surprised.
Best regards
Gertjan
sx881663 said:T,
I too have a nice amp3 setup, use it on my computer. I have built a UcD 400AD based amp as well. They both have the same rightness about them. The UcD is a whole level up from the amp 3. All the attributes are even more apparent with less dynamic compression, less distortion and real “kick butt” bass. Bottom line, the UcD sounds more like real music, is far more forgiving of various speaker loads and is just plain more enjoyable to listen to. To get this level of performance the AD version with input cap replacement is necessary.
Roger
Jocko Homo said:You think it was bad on this forum............!
At least no one told me that I was mentally impaired, and had an IQ around 50.
And at least you have a job.................
Jocko
t. said:
Thanks mate![]()
I do have a little Amp3 class T amp which sounds good for such a cheap tiny unit.
Obviously the UCD's are much more powerful but I hope the sound is as good, hopefully better than the Tripath TA2021 based amp3.
sx881663 said:T,
I too have a nice amp3 setup, use it on my computer. I have built a UcD 400AD based amp as well. They both have the same rightness about them. The UcD is a whole level up from the amp 3. All the attributes are even more apparent with less dynamic compression, less distortion and real “kick butt�Ebass. Bottom line, the UcD sounds more like real music, is far more forgiving of various speaker loads and is just plain more enjoyable to listen to. To get this level of performance the AD version with input cap replacement is necessary.
Roger
Jocko Homo said:For what......my age or IQ? Past one.........probably above the other.
Jocko
