ys audio preamp
Some film caps have the outer foils marked, and all can be identified using a generator and scope. Generally the recommendation is to orient the non-polar cap so that the outer foil is connected to the lowest impedance point in a given circuit. In low level circuits this provides some additional electro-static shielding, but in general is not too critical. (I do go to the trouble of orienting my caps this way in most all cases, but have not consistently heard the night and day "differences" some have claimed based on orientation.)
Yes true. I was thinking in terms of electrolytics as theyare polarized, since the input cap (0.22@63V) and output cap (1u@250V) could logically be electrolytics.
Film caps are not polerized per se, but as you point out have prefered orientation.
With that in mind, what is the recomendation for handeling the body of metal shell film caps like the K40Y-9? Leave the can floating? Ground it? Tie it and the outer film to the low impedance connection?
The metal can K40Y-9 (etc) is/are easy to measure for outer foil lead, since one can simply measure the capacitance from each lead to case and the higher capacitance lead is the outer foil one.
