Your Loudspeaker system Sensitivity
What sensitivity is your loudspeaker system, in dB
  • 95
    Votes: 8 20.5%
  • 94
    Votes: 3 7.7%
  • 93
    Votes: 1 2.6%
  • 92
    Votes: 4 10.3%
  • 91
    Votes: 3 7.7%
  • 90
    Votes: 4 10.3%
  • 89
    Votes: 4 10.3%
  • 88
    Votes: 4 10.3%
  • 87
    Votes: 3 7.7%
  • 86
    Votes: 5 12.8%
  • Total voters
    39
I know the title says "sensitivity", but it's easy to confuse with "efficiency". Also, the unit should not be "DB", but something "dB / 2.83 V(rms) at 1 m into 4pi" or something like that. Yes, that means that things can get a bit complicated to get the numbers right. However, as it is, the numbers are meaningless and cannot be compared because they are missing the spec for voltage, distance, and space.
I guess a proper explanation of the numbers would be in order to make this poll meaningful.
Reactions: ICG
speakers sensitive....?? it's not like when a raise my voice they pee on the rug...like the puppy does...so no i don't think they're sensitive.
why not have range categories of 5 db between 60 and 120?
is their no interest in tolerance and bandwidth these days?
I cannot vote.
I think most hifi speakers are somewhere between 80 and 85 dB (sensitivity on axis @2.83V/1m), and so are mine. This is based on the assumption that most (commercially sold) speakers are rather small 2-way systems.
But I agree that in the diy community higher efficiency speakers with their bigger size are probably common.
A few years ago I asked here on the forum how to measure the resulting sensitivity of speakers as precisely as possible, but the general conclusion was that if I don't make speakers for sale, then why am I interested.
In conclusion, at this moment I cannot say what is the sensitivity of the speakers where I listen to music.
I specify that I have access to quite accurate laboratory equipment, but not from the audio/acoustic field. For measurements, I would like to use an umik-1 and measure the input signal in the speakers with an oscilloscope or a trueRMS multimeter.
