basically....
I have 1000VA of transformers.... 9volts AC....
once rectified, how much capacitance to i need to keep the DC up with full load on the transformers, which is 80amps or so...
the mains is 50Hz... DC output from the rectifiers is around 12.5volts with a small load (lets assume 12volts under full load, they are big transformers)
THANKYOU!! 😀
THANKYOU!! 😀
its to run a car amp, in the house.... 🙂
edit: and maybe to jump start a car if it has a flat battery 😉
is ripple the right word?
I mean.. with a small load, and no capacitors, the DC voltage drops to 9 volts... while the AC stays constant.... ripple??
Download PSU Designer and find out. I suspect the answer is that you need a heck of a lot more voltage to maintain 12V at 80A. If you are ok with a lot of rail sag, then the requirements aren't as difficult.
tiroth said:I suspect the answer is that you need a heck of a lot more voltage to maintain 12V at 80A.
I'm abit confused by that statement...
The easy way out would be to buy a supercapacitor from a car audio shop. I guess 1 F should be enough. I would also put two smaller ones in parallel... maybe a 1 mF and a 1 uF.
You could also use Maxwell Ultracapacitors...
simon5 said:The easy way out would be to buy a supercapacitor from a car audio shop. I guess 1 F should be enough. I would also put two smaller ones in parallel... maybe a 1 mF and a 1 uF.
yeah, but would 1 farad actually be enough? or would 2 farads be better? or, is 1 farad overkill?
THATS my question 😀
Ok. 4.5-0-4.5 tranny, full wave rectified into 1F of capacitance. Assumptions: 1.1m source resistance, 2m capacitor series resistance. (better than you will see in reality!)
Load: 150m (80A draw at 12V)
RMS voltage: 6.6V
Ripple: 321mV p-p
Load: 300m (40A draw at 12V)
RMS voltage: 8V
Ripple: 232mV p-p
Load: 1.5R (8A draw at 12V)
RMS voltage: 10.2V
Ripple: 88mV p-p
That's what I meant by "you need more voltage."
RMS voltage: 6.6V
Ripple: 321mV p-p
RMS voltage: 8V
Ripple: 232mV p-p
RMS voltage: 10.2V
Ripple: 88mV p-p
Could he use BCAP0010 Ultracapacitors?
5 in series would give 520 Farads, I think he'll stay over 12.22 volts.
Adding more capacitance doesn't help unless your transformer/recitifiers can supply infinite current. Adding more capacitance just changes the conduction angle, which may not help you if you are already pulling down the tranny's voltage. You need to start with more voltage.
The 1.4x rule is only true if you are drawing lightly on the supply. As load increases, you begin to get only 1x RMS, and then even less than that as impedance losses add up.
As an aside, you can see why no one uses linear supplies to provide this kind of amperage. The losses are a lot lower in a SMPS and the regulation a lot better.
Use shottky diodes.
I have the same sort of situation with my electrolysis supply, I just paralleled some dual diodes (40A 30V) from switching power supplies and it gets about 5Vrms at up to probably 50-100A.
Ultracapacitors are NOT designed for filtration, except maybe if you use a filter inductor. Think of them as fast batteries.
Tim
Tim
what if I had 2000VA of toroidals, and only put the same 80amp load on them, are you saying I still wouldn't get 12volts, as I am only starting with like 12.7 unloaded?
skinnyboy:
Hi skinny, you would use a 2000va instead of a 1000va that is specified for the
job just to get a 0.7v better regulation, gee you are smart, i would suggest you
used a 3000va to get even better results
you would get better regulation thats for sure but the returns are small there are
better ways to tacle this problem without regulation, put load and Vtr into the
equation and save the capacitance for filtering
cheers
cheers
mastertech said:Hi skinny, you would use a 2000va instead of a 1000va that is specified for the
cheers
umm... wtf is your problem? I asked a question... I didn't say I was going to do it... now, if you wouldn't mind... **** off..
and i gave you my answear, and this is what i get?????
gee ask another question it will only get better i guess
cheers
cheers
mastertech said:and i gave you my answear, and this is what i get?????
cheers
even if you did give me an answer... you also basically called me an idiot....
The answer is you need more than 12V on any transformer you'd care to be carrying around with less than one person, to put out 12V 80A due to the voltage sag with higher current output.
Depending on the power supply section of the car amplifier, you might be just fine with a very low voltage but likely not.
Another route is to scratch-build a supply to suit the amplifier section... that is, bypass the switching supply in the amplifier altogether and make up a 35-0-35 or 70-0-70 or whatever it makes internally to supply the amp.
- Power Supplies
- you guys are smart.. :D help :(
