YjHifi 2x250w chip amp with bluetooth, gain?
Can anyone look at this board and maybe determine how to increase gain?
Maximum output is too low for BT purpose - around 2x10w, and with same results driving it via line input with mobile phone.
Chip is tas5630r
Thanks for any info!
I don't think so, feedback resistor divided by grid resistor gives gain for tube, opamp too I guess, but is it feedbackresistor, TI 5630evm surely makes it look that way, so increase gives attenuation, are the opamps active, working? or does signal bypass opamps through feedbackresistor maybe, I really don't know, guessing here. I would create a thread in analog line level with opa1632 in title, circuit is 5630evm, increase feedback resistor gives reduced gain, I could be mixing things up.
After replacing 10k with 40k resulting decreased gain (who knows why), I have done several things to try to make it louder. Here is what I have done:
Not sure exactly how much dB I have gained, but I suspect around +10dB, which is fine for now...
