Hello all,
I'm beginning the road to an Ono amp. I have a few ideas and
questions though, I haven't seen these really answered,
though one can certainly read about Onos for hours on diyaudio
(ask me how I know).
So far I've made the power supplies and I've got separate
chassiseseses for the PS/amps. I added a lot more filtering to
the PS, total supply filtering is 120,000 uF. Maybe takes a
while to get going...
1) has anyone tried to use surface mount components? Really
I'm only thinking of the resistors. Should be better due to
lower parasitics and shorter traces but maybe they sound
"bad", or perhaps not as good as the RN60s that are often used
and that are often used by Pass Labs.
I'm thinking perhaps Vishay/Dale CRCW series, 0805 or 1206.
Mouser has them in unit quantities.
There are only, what, 50 or 60 resistors per board, I can solder
that by hand. I have access to a good magnifying glass
intended for such purpose where I work.
2) If going with thru-hole resistors, Mouser doesn't have a
large selection of RN60. THere are lots of values in the Ono
schematic that are not stocked. BUt there are Xicon and KOA
SPEER 1% metal film resistors. Also IRC 0.1% metal film,
might be good for the RIAA. Anyone have an opinion on those
pro/con vs the RN60?
3) For the small value caps - the 100, 220, 330, 680 pF caps,
what do people like? Silvered Mica? Ceramic?
Tantalum is right out, they have a bad rap where I work for
realiability reasons.
4) To get 2 matched quads of the 2SK170s, how many should
I buy?
5) I'm planning to add 10 uF of film cap in parallel with C12, C20,
and C36. ANyone else do this? Would it be worth it to put
some relatively inexpensive film caps in those positions?
6) The famous LED that sets the voltage across R53... does
anyone have a Mouser or Digikey part number? It seems there
has been a lot of discussion about it but I can't find anywhere
that a part number is posted.
Thanks for any ideas / help...
W.
I buy?
W.
1.) I'm ordering some Koa RK73A SMD for audio for another project (check their website) but haven't tried them yet, but they are supposedly excellent... I think Goldpoint uses them in their steppers and they supplanted the Vishay-Dale SMD resistors in their lineup.
2.) I used PRP and Holco through-hole resistors with Roederstein Resista for the RIAA section. I purchased the former from PartsConnexion and the latter from Michael Percy Audio. I took plenty of time to carefully match these where it made sense, using some fancy equipment at work that could do four-wire measurements.
3.) I tried a lot of different caps and liked polystyrene (Xicon and some NOS from Ebay) as well as the Panasonic ECQP(Z) the best. I tried micas and liked them the least. In the end I went with the Panasonics. For the RIAA section I used Relcap RTE (Polystyrene Film and Foil) a MultiCap Film & Foil Polypropylene (PPFX) and a silver mica. I probably still have all the needed values in a few of these options around here
4.) I purchased 75 and got two well matched quads. My actual measured values are posted in one of the Ono threads. Also, there is another pair that should be matched as well, here I tried a bunch of transistors and decided that the BC550C sounded better to my ears. If I had to do it again, I'd also look at matching the IRF devices in the balanced section, as the actual ones in my finished Ono very wildly and I think this is why they run so hot (maybe not, just a guess).
5.) I use Black Gate NX capacitors and Black Gate standard grade and didn't at all like the sound of them bypassed. As for the 10uF output capacitors I used Clarity Caps bypassed by Roederstein MKP 1837. These sounds quite nice. I tried some of the cheaper Mundorfs and some Wima 10uF and prefered the above configuration. Maybe one day I'll try Auricaps, but the entry price was too steep for me.
6.) This guy is hard to find, I purchased 100s of LEDs from Mouser and Digikey and all were around Vf = 1.7. IMHO, don't bother looking, as you won't find them. Better instead to tweak the resistor values then mess with finding the right LED. However, if you want to go down this path, the final LED I used was pulled from a computer and was a red T1 sized from a 3.5" floppy drive. One idea might be to use two infrared LEDs in series. IMHO, the correct value helps the sound tremendously. Here a .1 V makes a huge difference in the heat and the sound and makes sure that the gain switches work (I had this problem before I found the right LED and this fixed it right up).
Take care!
edit: I noticed you're up in Dallas. If you're ever in Austin, holler at me and you can take a listen to my Xono 😉
Take care!
Thanks for the reply... I've got a lot to look into now.
I looked up the KOAs - where does one buy the small qtys a
person like you or I would buy?
wayne325 said:Thanks for the reply... I've got a lot to look into now.
I couldn't find anywhere as well, so I used this as justification to request samples from KOA 😉 They have not arrived yet, and that was 2 weeks ago, but I did get some sort of order confirmation.
Update:
I've ordered all the silicon bits needed except the stuff I can
get from Digikey easily. I'll have 2SA929 instead of 2SA991.
The rest is being entered into spreadsheet as a mix of
PRP, Holco, as the preferred resistors and RN60 where I can't
get the right values. RIAA is only exception since they seem
to be little used values. I'll look into the Rodersteins for the
RIAA but there are KOA as I wrote before. I decided to go
with thru-hole resistors as they are easier to handle.
I'm still a bit confused about that pesky LED that biases
Q16 and Q17. I thought the Veb of a BJT operating in linear
region is a diode drop = about 0.7V. If we want 1.0V across
R67 and R53, then it should be fine given the base current
through R22 and R55+R54 should be near 0, and so the
voltage drop across those resistors is also near 0. So what
am I missing since the 1.0V + 0.7V is equal to 1.7V which
is the Vf of the LEDs you measured? It seems to me like
1.7V is what we want for the LED. I'm going wrong somewhere.
Does anyone know where my error is? More to the point, what
Vf do I want in the LED D5 in order to get 1.0V across R67 and
R53?
R53?
I'm hoping someone can help me out with the LED part and the
associated circuitry.
I believe that Q16 is acting as a current source for the 2SK389
differential pair. The biasing is done by R67 which is 475 ohms.
If we want 1.00V across R67, that means the current source
is drawing 2.10mA. If I look at the curves for 2SC1844 (Q16),
I see that Vbe for Ic = 6.0V (the only curve available) is right
around 0.6V.
If we assume that Ib = 0 then the drop across R22, the base
resistor of Q16, is 0. So to have 1.0V across R67, I need
to have a LED with Vf = 1.0 + 0.6 = 1.6V.
And that takes me to the problem. The Mouser and Digikey
are full of LEDs that have Vf as low as 1.7V, but none as low
as 1.6V.
So.
What I have to do is get a LED with the lowest Vf I can find,
and then change out R67 so that the current through it
is 2.10mA. Assuming a 1.7V LED, I'd need to increase the
voltage across R67 by 0.1V in order to keep the bias current
at 2.10mA, and so I'd need 475 + 47.5 ohms = 522 ohms.
The point is, I have to bias the differential pair to 2.10 mA.
If the collector voltage of Q16 is up 0.1V or so, that doesn't
much matter at all.
The Q17 side gets the same treatment only I change R53 to
about 165 ohms or so.
THe other thing I can do is adjust the current of the LED by
changing R5 but I have no curves for any LEDs so I don't know
how much I can affect things there and I don't know if lowering
the current will allow the voltage to drift or be less stable.
I guess that's what C27 is there for though.
Did I get that about right ?
(Dammit Jim, I'm a digital guy, not an analog guy)
around 0.6V.
as 1.6V.
So.
much matter at all.
I've bought and measured from Mouser this part:
696-LX5093SRC/DV
But I haven't built the amps yet and I don't know what current
I need. With a target of 1.7Vf, I need about 12k resistor to
bias it. I'll see what happens. Oh ya, I'm going to layout a
trimmer so I can play with the level current.
If I want after it's set I can measure and replace by a fixed resistor.
Thanks for the part#... if I'm way off I'll try it.
W.
696-LX5093SRC/DV
W.
good to hear. just thought that point six in post two indicated that the 1.6V LED was a unicorn when mouser, digikey, rs-components et al do stock a LED that should be close to that figure.
I've had a set of Ralph Stens' (X)Ono boards since early january this year and have been thinking about finally pulling the finger out and building them up. Still need to pick up the psu board, but if i wait til the 26th I can order on the 12 month anniversary of ordering the channel boards 😉
Still checking out parts sources - at this stage I think I'll go for Vishay VSH-J bulk foils for the RIAA resistors and PRPs for the rest.
spzzzzkt said:good to hear. just thought that point six in post two indicated that the 1.6V LED was a unicorn when mouser, digikey, rs-components et al do stock a LED that should be close to that figure.
I used PRP as well, but you'll have to suppliment with another line as PRP is not extensive enough. I used some Holco as well. If the proper RIAA values aren't available in Vishay bulk foils, they definitely are in Roederstein Resista, which Michael Percy carries.
Don´t care about leds
Hi all,
To me is incredible, how many is discussed about one simple led.
Papa Nelson (or Wayne Colburn?) stated in the service manual: "R53 and R67 at 1 volt after the base emitter drops. This reading across these two resistors is important for this stage to work properly."
This only means that is necessary 2,1 mA and 6,7 mA in the CCS's.
The simple way to obtain this target values is by tweaking the values of R67 and R53, wathever the led used.
Conventional red led give 1.9V with 4mA (R5=6k8), wich calls for about 570R for R67 and 180R for R53
If the final goal is to obtain a aleph ONO clone with identical sound to originals, electrolictics C1, C41, C 12, 21, 22, 29 and all film caps have to be identical to the originals.
And, if necessary any fine adjust in Vled, tweak the value of R5 give some results. the led is happy in the range of 1 to 15 mA. I have measured 1.83V with 1 mA and 2.0V with 10 mA.
Some "crystal" red leds with medium efficiency exibits exactly 1.7V @ 4mA.
Hope this help.
Marcos
Hi all,
Hope this help.
Marcos
Dear Wayne,
I've read your posts after posted the above, you is the right track.
Actually, the lower the current, the more is thermal stability, cause lower heating in the junction. And do not forget the fact R5+Led receive voltage from a stabilized power supply, wich means near constant current for the led.
Marcos
Marcos
I had been looking at using beyschlag/vishay/phillips mrs25 resistor which are the Audio Note entry level and available from a local surplus barn at a reasonable price. However, some posts to diyaudio and availability of correct values have convinced me to try out the Holco/PRP combination you suggest. According to MP's catalog he should carry the VSH-J in all the required values for the RIAA resistors.
OK heres the latest.
I have boards and I've stuffed all the components.
When I fired them up, they seemed to be pretty good - but not
100% yet. After turning on, making adjustments as appropriate
I decided to go for the "Hail Mary" by connecting to stereo,
given the outputs had no bad DC offset voltages. I didn't have
a scope at home so all I could measure was voltages. Yes I
was as careful as I could be with my setup - starting out at the
lowest volume position (after all the mutes were lifted).
When connecting to MC source input, both channels seem to
work pretty good, except gain is far too low. Turning up preamp
volume to full gives clear sound with at least decent frequency
response, but as I said, it was nowhere near 76 dB gain.
I had a Pearl in there before and if the Pearl is around +40 dB's,
I'd say right now my Onos are in the +30 dB range or so.
So clearly I have to get a scope in there with a signal generator
and I'll start down that road this weekend a bit.
For now though most seems well, I can adjust the R28 to 0.350V
easily, and I see about 1.11V across the R36's and 1.10V across
the R40's. So the main part of the amp is at least nominal in
terms of the current sources and the active components being
sane. I do have to adjust the resistors above though to get
the voltages down from the 1.1V range to the 1.0V range.
For now I have a question I hope someone can help me with.
When I have the shorting plug NOT shorting out R66 (the -4dB plug).
I see these voltages on Q14:
E = 3.6V
C = 3.3V
B = 4.1V
and the voltages across R45 - R48 are between 110 and 180
mV (ie not very well matched)
When the shorting plug IS shorting R66,
E = 12.2V
C = 16.7V
B = 12.8V
and the voltages across the R45 - R48 are all very close, at
93 mV, say +/- 1 mV.
I bought 65 2SK170's, and I have fairly well matched quads so
the currents thru the R45 - R48 should all be close, which they
are when the emitter of Q14 is at 12V.
Does anyone know what might be wrong here? Is there even
a problem? FWIW, both amps are behaving exactly the same
and the emitter of Q24 (the MC regulator output) is rock solid
at 26.1V whether or not the shorting plug is inserted. I have
gone through the circuit to see that it matches both the schematic
I printed years ago when the Pass site had these posted, and
I also checked against the schematic "Promitheus" posted
on a related thread (they are the same, except things like
extra bypass caps that don't matter).
E = 3.6V
C = 3.3V
B = 4.1V
E = 12.2V
C = 16.7V
B = 12.8V
Dear Wayne,
Your preamp appears to have the right behavior with given current values in the fets. 93mV on 22R is about 4,2mA per fet, total is about 17mA. with one resistor (R40) 499R, you have a drop of 8,43V on this, wich give about you measured in that condition. BUT, if you have 499R two times (J1 open) the total drop on this is too much to give a correct operation of the cascode. 4 solutions come in mind:
1) utilize fets with half of IDSS you actually have,
2) Raise the values of drain resistors,
3) use only two fets instead four (the rise in noise is very little), and,
4) Forget about J1, left this always closed.
don't care to much about exact voltages, about 20% tolerance is harmless for audio work, specially in those capacitor coupled circuits.
Hope this helps,
Marcos
Hope this helps,
Marcos
Marcos:
THanks for the info.
I did find one problem in that part of the circuit - I had captured
my schematic with C37 reversed polarity, and when I had shorted
R66, C37 became reverse-biased so it was no longer operating
like a cap. My design actually used 2x 470 uF in parallel in
place of C37 and C19, (bypassed also) so what I did is remove
both of the "C37" caps, and also one of the "C19" caps, and
I turned around the one I scavenged from the C19 position,
and I now see maybe 10.3 or 10.5 V at the emitter of Q14
when R66 is shorted. So that is fixed, and I now have bypassed
C37 and C19 both at 470 uF.
I then turned my attention to getting the MM and the INV amps
operating correctly.... and I've spent hours messing around
with hum problems. And that's where I'm at right now. It is
not fun tracking this down because you can't use test
equipment to measure for it. I have made one large stride
though and I have one more small change to my grounding to
make it identical to the way I had my Pearl grounded. Wish me
luck because I'm about at my wit's end, if this last change
doesn't work, I've run out of ideas.
Once I get past the hum, the good news is that the MM and the
INV amps both appear to be working fine as there is good music
coming out of the system (albeit the gain is far too low to be
useful) overlaid by an unacceptable amount of hum.
THen after the hum is dealt with I will again turn my attention
to the MC amps and see what else, if anything, is still wrong
in there - I would doubt it unless I've toasted some actives
when the cap was turned round the wrong way.
W.
W.
OK... good news. The one thing I was going to do turned out
to be a good fork in the road. When I get a chance I'll post a
pdf with a drawing that shows what I arrived at.
I'm going to stop now for a week or two on this and then pick
up again with the MC amp.
For now I'm going to enjoy the amp the way it is.... with the
gain on my pre turned up almost all the way since I have a
low-voltage MC cartridge (which is why I made this amp in
the first place... the Pearl doesn't have enough gain, great
little amp though it is).
Over and out for now....
Wow... even better news.
This amp ROCKS.
I just put on Clapton's Unplugged, side 1. I like the music and
it is technically a very good or excellent recording. There is no
comparison between the Pearl and the Ono. The Ono has far
more separation, detail, air, and extension high and low. And
I'm taking about an amp that has been running for maybe 3
or 4 hours total right now between all the hacking I've done
since I completed it on Thursday.
Keep in mind also that I'm running a low voltage MC cartridge
into the MM input and cranking my pre up pretty much all the
way. I suspect when the MC section is fired up and the pre is
turned down a bunch it'll get even better.
Oh, and Wayne.... yes it does have a nice firm bottom. Thanks
for the great design.
This amp ROCKS.
I concur with that bottom thing...
Just finnished my ono yesterday as well. i basically had the same problems with the MC frontend section and decided to use 27 ohm source resistors and only mount one 500ohm gain resistor.
I also lowered the drain voltage to 12V to create a bit more voltage margine on the cascode circuit.
Next problem was the LED reference in the MD section. The led voltage was too high resulting in a high current in both current sources. I changed the resistors to 680 and 220 ohm to get the approx currents.
Now the bias current for the output stage was way more easy to adjust and one channel came to life.
The other channel had strange noises at the output and would not give undistorted output below 20mA bias (about double the intended value) Also toutching the 2SK389 would increase the humm and RF demodulation in this channel.
I concluded that this channel was oscilating and I had to find out why.
The only very obvious occilating prevention in the MD section is the 100p cap, however it was soldered in place and had the correct value. Yet placing another 100p cap across the original made the channel dead silent. Later, after replacing the 100p cap I found that the value was incorrectly stampt and in reality it was a 10p cap.
Last point I still have to solve is the grounding. This is where I would like to have your input. How did you layout your grounding and do you also have a faint humm in your ono?
Thanks...Marcel.
PS. despite the slight humm...This amp play's very very well indeed.
Thanks Wayne!
Thanks...Marcel.
Thanks Wayne!
- Yet Another Ono Thread
