Prelude WL-15
Specifications:
Viewable Area: 15"
View Angle: 120
Resolution: 1024x768
Pixel Pitch: .297mm
Contrast Ratio: 400:1
Color Depth: 16.7 million
Response Time: 10 msec
$249.00 Free Fedex Shipping!
http://www.newegg.com/app/viewproduct.asp?description=24-171-001&refer=pricewatch
GREAT response time. I already ordered the WIN CMV 1512 from MS4ME and should be getting it tomorrow, so this is just a heads up for anyone who is still looking.
It's about 15 dollars more than the CMV 1512, but you also get faster response time and better shipping, so it may be worth it for some people.
Also, there are alot of great user reviews on my link page.
Specifications:
Viewable Area: 15"
View Angle: 120
Pixel Pitch: .297mm
Sounds like a nice panel - have you taken it apart yet and if so was it easy to do? Any cable extensions needed?
Thanks,
Steve
Thanks,
Steve
Pardon my disbelief, but I don't think there are any 10ms response LCDs yet.
10ms is probably the rising or falling time only. You need both to calculate a real response.
read the cusomer reviews at the bottom of the page, I'm thinking its 10ms response because it will usually say if its rise or fall
http://www.streetprices.com/Electronics/Computer_Hardware_PC/Monitors/LCD_15in/SP1169190.html also quotes it as having a 10ms response time - I agree this is not the best of sources of information.
However having not found any "proper" spec sheets, this and the original post are the only things I have to go on.
Steve
Steve
Full Specs
Model WL-15
Display Type: 15" active matrix TFT LCD panel
Pixel Pitch: 0.297 (H) x 0.297 (V) mm
Max Color: 16.7M
Display Size: 15"
Viewing Angle: Not Specified
Resolutions Supported: 1024 (H) x 768 (V) XGA
Recommended Resolution: Not Specified
Response Time: 10 msec rising (typ.)
Brightness: 300 cd/m2 (typ.)
Panel Surface: Not Specified
User Controls: Not Specified
Input: Video Signal RGB analog 0.7V peak to peak
Signal Cable: Not Specified
Frequency: Not Specified
Operating Humidity Range: 20%~80%
Operating Temperature: 0°C~45°C
Power Management: Not Specified
Power Supply AC Input: 100-240V~1.8A, 50-60Hz; DC Output: 12V / 3.0A
Regulatory Approvals: CE, TüV-GS / MPR II, UL and CSA
Cabinet: Color Silver
Dimensions: 375(H) x 353(W) x 188(D) mm
Model WL-15
Max Color: 16.7M
Display Size: 15"
i made a post about that panel earlier, i had never heard of the company before however, and no1 seemed to know if it was strippable...
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Yet another inexpensive monitor with great specs!
