Yet Another Aleph J Build
:cuss: making me think!!! How about pointing me toward a schematic of the version prior to this?
I described the differences here including some of the design topology:
So a little word on some of the technical differences between the two designs. It's very easy to see that ZM has tightened up his version particularly in a more compact layout, use of cascode regulation for the input JFETs and finally some current sources. The output stage uses the Aleph CCS but with IRF 150's which provide intrinsic matching! As such it is a much more turnkey method of building an Aleph J. There is no need for matching the output devices whatsoever.
Best,
Anand.
  • Thank You
Reactions: Toys4Boys
as it seems you didn't post it, here it is, schm of built one
I agree with the sentiment ferrules are the way to go. Bare wire works but ferrules stand the test of time better. when you look in most control consoles for CNC and like machines they use ferrules all the time to complete connections.
Just powered up my Aleph and had a hum through the speakers, not 60Hz, very similar to my SuperNait 3 if it has an "inductance" hissy fit. Powering down, briefly, no effect. Remove the left channel RCA and that channel stopped, did the right, same, re-connected and it's gone. There is 1 other difference in the system, yesterday I connected MFF RCA's and connected my sub.
OK, then situation is clean - question for Gianluca and guyz already having them in hands
if hole from back is either 5 or 3mm Dia , then smaller hole in front is just light window, all what's needed is to push LED in protrusion from back
personally I like that approach - 3 or 5mm Dia protrusion, 1mm Dia hole for light
