Yamaha THR10 amp - need a part!!
I picked up this amp (not "working") cheap, and (with batteries) it sounds incredible. Problem was the socket for the 15VDC wall wart has jacked. Unsoldered it, had one leg broken - ah-ha?...not quite. PCB showed positive lead, so I soldered red & blk wires to it, but still no power. Wish I had the schematic! Bad socket had 3 terminals, possibly to switch out the battery source... Where can I get this socket? Has no numbers on it, pcb says only "JK501". Don't want to install any socket, if it has special switching. Thanks!
I called, they say they're closed.... but thanks for the tip, I'll get up there soon.... Got the amp back working, turns out the defective jack has a contact inside that feeds the batteries when it is not getting wall power. Just shorted the right wires, and back on batteries (for now)...
