yamaha rxv 795 av amp
Hi all currently working on a yamaha av amp ,5 channels,switch on for 1 second switches off,
Checked all 10 output trannys,repaced 1 and driver and predriver
changed rectifier
changed psu caps
Still the same get +and - rails all over it
The fault i had was the main right channel first output tranny fed from psu
YAMAHA RVX-795 AV AMP
Did you ever get the amp fixed as mine has started behaving in a similar manner. Shuts down after a second. I have checked the output trannies and volatges which seem fine. I will try and check the capacitors but I am runnin out of options
