Yamaha CR 2020 power supply
Hi all,
I have performed the service bulletin modifications on mine and have a strange issue with the voltage on the collector of the negative regulator pass transistor.
I’m getting +/- 36 volts in to the board ( NB+ & NB- ) and see the raw +38v DC on the collector of the positive regulator pass transistor, as well as the expected 100hz ripple.
On the collector of the negative pass transistor I measure about 28 volts and see no ripple.
The power supply is supposed to put out +/- 25 volts and puts out +/- 26.3 V.
I recapped it as well as installing TIP41Cs in the place of the original SD234 ( TR712 and TR715) pass transistors but am a bit worried about this strange result, any ideas?
Service manual is here: https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Yamaha-CR-2020-Service-Manual.pdf
Many thanks,
