Only one channel works? Other channel OK? Please elaborate.I desoldered q118 q119 ,not protect mode, Amplifier works with only one channel.
2 transistors are ok
Details?And all power transistors are hot
170mV across what resistors/combination of resistors? Need more explicit detail.The bias of power transistors is very high.....170mv on both channels
Would you report base-emitter voltages for Q129C, Q129A, voltage across R137 resistors from center to each emitter, and amp output to ground. Same for other channel.
Next if bias currents remain high, would you install a short across R127, and report change in bias current? This is a diagnostic test, not a remedy. Same experiment for other channel if appropriate.
