Yamaha Amplifier
But the display is okay and the filament also good glow in dark when I see it close up.
It can still be low emission from the filaments. As others have said, supply issues should be checked as this is a really common cause of dim displays. Often a capacitance voltage multiplier can be used to derive the high negative voltage needed and the caps go bad.
There are examples on the web of trying to rejuvenate VFD's when the filaments have gone low emission. How successful it is I can't say but theory is very sound in that you are attempting to burn of a layer of contamination on the filament to reveal a fresh emitting surface.
Reactions: Logon
