Xtant X1001
My friend came over with one of theese..
I removed all power supply fets since they were shorted..
I replaced all 4 of the A56's on the board also replaced the 10 ohm resistors..
Left the power supply fets out and hooked the amp up to look at the gate signal ..
With no power supply fets installed the amp burns all 4 of the A56's in it within 5 secs Any ideas?
Heres a pic of the square wave on the base of the 56's
Scope is set to 5us .5 volts div
Please read that section again. Page 73 on the car audio site. Using standardized settings eliminates the need for me to ask half a dozen questions.
After setting the scope as suggested, post the waveform again.
Again, this needs to be done with the 10 ohm resistors and the four A56s out of the circuit.
